Can you distribute multiple objects to multiple layers???
All  1-7  8-11
5498.8 In reply to 5498.7
Hi Martin,
quote:
Here Sneather wants to be able to use the same functionality of having a script or command that will cycle through the objects either exporting ready for C4D or to just have the objcects named individually so they can then be imported into C4D and have their own mapping co-ordinates as individual parts rather one solid lump because of everything being on the same layer at export
Ok, but I have explained how to do that above...
That information again is:
The script here will cycle through objects that have the same name and break them into having individual separate names:
http://moi3d.com/forum/index.php?webtag=MOI&msg=3114.5
To use it, select everything and assign it all one name, then run the script and it will cycle through the objects as you are describing.
If it's not just object names that you want set up individually per object but also one separate style for each object (so that each object has its own individual material when importing into C4D as well as it's own object name), then do the process for separating out the names and then additionally run the script here which will set up one style for each named object:
http://moi3d.com/forum/index.php?webtag=MOI&msg=3334.2
As far as I can tell those cover what you are describing - if those do not do what's needed then I'll need more detailed information.
5498.9 In reply to 5498.8
Well it's cool beans from me, they sure would have been handy when I was having fun pulling that model apart for export. As always top notch support
Martin
5498.10 In reply to 5498.9
Hi Martin, sorry I didn't really know these would have helped you at that time, I guess I was focused on the part of your request about doing separate meshing settings for each individual object which is not covered by what I'm describing here.
The scripts listed here in this thread are also on Petr's page here in the "Browser" section:
http://kyticka.webzdarma.cz/3d/moi/
5498.11 In reply to 5498.6
Hey Michael,
Sorry for making this topic hazier than it needs to be, and thanks for trying to help.
For now I'm moving on. I resorted to asking the engineer to re-export the file in a better way. So, I'm good on this job.
Cheers!
Show messages: All  1-7  8-11
