Thread cutting script - WIP
 1-7  …  48-67  68-87  88-107  108-110
5451.88 In reply to 5451.87
hep
>> i wonder if you plan to add different heads like sucket cap or countersunk head for different screwdrivers (hex, torx, PH1, PH2) in the future?
Hi. At the moment I have no plans to continue developing it.
5451.89 In reply to 5451.88
Hi Max, ok - I like the script anyway :-)
5451.90
Amazing work.
I'll try to install it.
Guys...you're really great!
Thanks for all the job you're doing.
I love this community more and more everyday!
Moi and this community RULEZ
Arian DESIGN
www.arianshamil.com
5451.91
how do I install the script?
Thx,
Sven
5451.92 In reply to 5451.91
5451.93 In reply to 5451.91
Hi Sven,
Please see this new FAQ answer, it explains how to install plug-in scripts:
http://moi3d.com/wiki/FAQ#Q:_How_do_I_install_a_plug-in_script.3F
EDIT: Beaten by Max! :)
5451.94 In reply to 5451.93
Thx, I got it in meantime. Couldn't find the thread again... :-(
5451.95 In reply to 5451.74
Hi Max,
How did you make that awesome hatching effect on the side of the two blocks?
5451.96
Hi Max, I just tried your _NutsandBolts script with V4 beta Nov-27-2017.
It works but when I select a 1/4" thread this error pops up:
5451.97 In reply to 5451.96
Hi Martin,
Thank you for bugreport
I'll check it tomorrow
5451.98 In reply to 5451.97
unfortunately it doesn't work with MoI 4.0 beta Sep-10-2020
5451.99 In reply to 5451.98
5451.100 In reply to 5451.99
this one works. thank you!
5451.101 In reply to 5451.98
Something seems strange.
Nuts and Bolts (v0.96) gave that same error.
The version 4 from Pilou worked.
Then the "older" version started working?
Or else with all of my deletions and copying, an even older version was overwritten.
Or else the v.96 doesn't work for a brand new updated beta??? But does if there is some change in V4?
My versions are too far scrambled up to do any testing now...Until a new beta or final MoI comes out???
5451.102 In reply to 5451.101
Hmm, I just tested Max's latest Nuts and Bolts (v.0.96 Martin, Max Smirnov 2015.06.21) with 4.0 Beta Sep-10-2020 and it works without error. I also have a slightly newer 4.0 Beta Sep-16-2020 (addresses a specific bug) and it works properly there as well.
--Larry
5451.103 In reply to 5451.99
There are a few issues with the French version of Max's "_NutsAndBolts":
- Standard US UNC threads are gone.
- The sliders for the settings of the chamfers of the screw heads and the nuts are so small that they are inoperative and make the script buggy.
- It would be necessary to replace "Thread length" by "threaded length" because otherwise part of the script, on the right, is hidden.
- I think, but it's personal, that it would be better to use the term "Stem" instead of "Fitting".
The 2 images below illustrate my point well, Max's original and the French version.
I discovered these little problems while having fun making industrial and/or mechanical parts with American threads in inches and French threads in millimeters, UN (ANSI) unified threads and ISO metric thread.
- Zooen
Size: 81.4 KB, Downloaded: 33 times, Dimensions: 177x499px
Size: 84.4 KB, Downloaded: 24 times, Dimensions: 175x497px
5451.104 In reply to 5451.103
As has been done in some other scripts, it should be possible to make the sliders on separate menu lines, for a bit more text space.
5451.105 In reply to 5451.103
Hi Zooen, here's a version of the French nuts and bolts script that allows word wrapping so it doesn't have pieces of the UI cut off.
5451.106 In reply to 5451.105
Thank's Michael, (thank's Brian)
I added the UNC threads which disappeared for the French version (?) in NutsAndBolts.htm.
In France and Europe, these threads are sometimes used in certain CNC or other machining parts.
- Zooen
EDITED: 27 Oct 2023 by ZOOEN
Size: 348.2 KB, Downloaded: 15 times, Dimensions: 890x357px
Size: 30.9 KB, Downloaded: 10 times, Dimensions: 160x132px
I will add that on the French Repository! ;)
Show messages:  1-7  …  28-47  48-67  68-87  88-107  108-110
