If you ever get into this again, an "enhancement request" would be a metric/imperial radio selection to limit the options container to one or the other.... Obviously not something "wrong", just a suggestion.
How feasible is a Gear, Spring or bearing script? I think there is already a gear script out there but to have things like different tooth profiles and and bevel options and other related options would be something else. Something like this but for MOI - http://geargenerator.com
BTW I admire your generosity to the forum, but i can appreciate that this must take up considerable time. I personally would pay $10 - 20 for these highly developed scripts
this is such a need script. i wonder if you plan to add different heads like sucket cap or countersunk head for different screwdrivers ( hex, torx, PH1, PH2) in the future?
hep
>> i wonder if you plan to add different heads like sucket cap or countersunk head for different screwdrivers (hex, torx, PH1, PH2) in the future?
Hi. At the moment I have no plans to continue developing it.
Something seems strange.
Nuts and Bolts (v0.96) gave that same error.
The version 4 from Pilou worked.
Then the "older" version started working?
Or else with all of my deletions and copying, an even older version was overwritten.
Or else the v.96 doesn't work for a brand new updated beta??? But does if there is some change in V4?
My versions are too far scrambled up to do any testing now...Until a new beta or final MoI comes out???
Hmm, I just tested Max's latest Nuts and Bolts (v.0.96 Martin, Max Smirnov 2015.06.21) with 4.0 Beta Sep-10-2020 and it works without error. I also have a slightly newer 4.0 Beta Sep-16-2020 (addresses a specific bug) and it works properly there as well.
