Precise placement of points
All  1-3  4-6
5294.4 In reply to 5294.1
Hi Rachel, also if you haven't seen it yet, check out the introduction section of the help file:
http://moi3d.com/2.0/docs/moi_introduction.htm
It has some information about general operation of MoI and the section for Drawing / Picking points covers some of this stuff with some other information mentioned there too like how construction lines work.
Also in addition to that check out the video tutorials here which can also be a good help for getting started:
http://moi3d.com/2.0/docs/tutorials.htm
5294.5 In reply to 5294.4
Hi Michael, thanks so much for this information. I'm able to place points in arbitrary locations using the keyboard as you suggest (I'm already familiar with most of the other special inputs like radius, as they come up when that command is used). It's a little awkward as I have to write down the coordinates while moving the cursor into 2 or 3 views to get all the right numbers, but it works. I will re-read the intro because clearly I missed some stuff before!
Rachel
5294.6 In reply to 5294.5
Normally you would use direct x,y,z input when you already know the specific coordinate that you want to have, like if you're reading blueprints or plans that specifically call out a coordinate location. I had thought that's what you were asking about.
But it sounds like you're trying to do something different than that - something like eyeballing a location between multiple views or something along those lines? Something like that is probably better done by creating construction lines or drawing in helper lines and then using those to snap on to, rather than trying to write down existing coordinates. Mostly any time that you would be writing down coordinates it's a sign that some kind of snapping based drawing tool would do that job for you without any written down coordinates required.
Either construction lines, regular drawn lines, or placing a "point" object may be ways to get what you need done without writing own any coordinates. The "point" object is a marker that you can place and then snap on to later, it's available under Draw curve > More. Construction lines allow you to create temporary lines to help out with all kinds of alignment, extension, and positioning tasks, there is a bunch information on them here:
http://moi3d.com/2.0/docs/moi_command_reference11.htm#constructionlines
Can you maybe describe in a little bit more detail exactly what you're trying to do? If you have a particular file that you are working with it would also help if you could post the 3DM file as an attachment here.
Show messages: All  1-3  4-6
