Solo view?
All  1-3  4-6
5059.4 In reply to 5059.3
You can make keyboard shortcuts to move to views too.. This is what the "command part" would look like for Top:
script:var vname = 'Top'; var vp = moi.ui.mainWindow.viewpanel; vp.mode = vname; if ( vp.getViewport(vname).name != vname ) vp.reverseView( vname );
Note the word "Top" in there.
You can set that word to any of the views:
Back
Bottom
Front
Left
Right
Top
For Split view and 3d viewport, the script is:
script:moi.ui.mainWindow.viewpanel.mode = 'Split';
Note the word "Split" in there.
You can set that word to 3D:
5059.5
I found this script to be UBERuseful, which will switch between the viewport under the current mouse cursor location and the quad view.
script:if ( moi.ui.mainWindow.viewpanel.mode != 'split' ) { moi.ui.mainWindow.viewpanel.mode = 'split' } else { var viewport = moi.ui.getViewportUnderMouse(); if ( viewport ) viewport.viewpanel.mode = viewport.name; }
..just put it on the SPACE key or (almost) any other key combination like so:
http://moi3d.com/2.0/docs/moi_command_reference11.htm#shortcutkeys
Cheers,
Marco
EDITED: 11 Apr 2012 by MARCO
5059.6 In reply to 5059.5
Wooo thanks... Never seen this script.. Works great.
Peace,
Rich_Art. ;-)
Show messages: All  1-3  4-6
