Problem with revolve-curve
All  1-8  9-15
4587.9 In reply to 4587.8
Hi mike, thanks for posting the 3DM file!
So first re: deleting the revolved curve - from what I can see in your file your original revolve curve is actually hidden and also located a little distance down below your solid shapes. If I display it, it seems that I can select it and delete it ok.
The thing that you see that is attached to your solid is not the revolve curve - that's the "seam edge" of the surface. You don't want to delete that since it is a built in part of the surface itself. Every surface in MoI has edge curves that define its boundary and in the case of a closed surface like a revolve it's like you have a sheet of paper rolled up with 2 opposite edges of the paper touching each other. That's a normal part of the surface and not something to get rid of.
The generator curve will be another separate object from that entirely.
4587.10 In reply to 4587.8
Hi mike,
> I first made the revolve
> Then I made the second spline for the handle or whatever.
> Then I did a trimm command
> Then I extruded the inner face I got from the trim
That's an ok way to do things especially if you want the top of the extruded piece to have the same kind of rounded shape as the revolve.
But you'll need to do a bit more work to get the pieces all joined together into a single solid so that you will have some joined edges to be able to fillet.
When you do the extrude of the inner face - that makes a little self contained solid out of the extrusion and you'll then need to delete the bottom face of that so that there is an unattached edge at the bottom of that extrusion that then matches to the other unattached trimmed away edge of the revolve, then you can use Edit > Join to glue together those pieces into a solid.
4587.11
You're right. Its the seam.
But anyway, after deleting the original revolve-spline
then its the seam-curve of the revolve which distubs in my case.
Maybe I'm doing something totally wrong.
So whats the best or correct way to do this kind of operation?
Btw. is it possible to seperate optical (f.e. by color)
"seams-curves" - "intersecting curves" and "construction-splines"?
thanks
Michael
4587.12 In reply to 4587.11
You can control the colors of things by assigning them different styles - that's done by the properties panel or by clicking on a color swatch in the scene browser:
http://moi3d.com/2.0/docs/moi_command_reference11.htm#propertiespanel
http://moi3d.com/2.0/docs/moi_command_reference11.htm#scenebrowser
Basically colors are left to be used as a kind of grouping mechanism by your own preference, so there isn't anything like make all construction splines a particular color separate from the style system.
4587.13
sorry again!
another problem I have is:
I want to merge f.e. 3 separate faces.
I run the "merge"-command - the I selct the 3 faces -
and then "enter".
But after that, I still have these 3 faces sepeate.
thanks
Michael
4587.14 In reply to 4587.11
Well, you're not really doing anything wrong other than needing to get the whole thing joined together as one piece.
Sometimes seam curves can tend to get in the way and that's what's happening to you here.
With the pieces all joined together into 1 solid (see attached 3DM file), then fillet looks like it will be able to generate a partial result but it has difficulty trimming the objects back so the fillet piece that gets generated will have to be manually trimmed into place.
Let me know what fillet radius you want and I can help you do that.
Also the one main thing that would probably make it easier is if the midpoint of your shape was actually aligned to the seam instead of shifted just a little ways to one side - is that intentional that your top shape is not symmetrical around the center of the revolve?
By the way it's late over here so I'll probably have to continue tomorrow.
4587.15 In reply to 4587.13
> and then "enter".
Do you mean the Boolean merge command? The boolean commands are more for slicing up pieces that need to be intersected with one another.
If you have things that touch at common edges and don't need to be sliced up, then use the Edit > Join command rather than the boolean merge command to glue stuff like that together.
So probably in the case that you're describing there you would use Join, not boolean merge. If that's not right please post a 3DM file with your 3 surfaces in it so I can check them out.
Show messages: All  1-8  9-15
