Problem with revolve-curve
All  1-10  11-15
4587.11
You're right. Its the seam.
But anyway, after deleting the original revolve-spline
then its the seam-curve of the revolve which distubs in my case.
Maybe I'm doing something totally wrong.
So whats the best or correct way to do this kind of operation?
Btw. is it possible to seperate optical (f.e. by color)
"seams-curves" - "intersecting curves" and "construction-splines"?
thanks
Michael
4587.12 In reply to 4587.11
You can control the colors of things by assigning them different styles - that's done by the properties panel or by clicking on a color swatch in the scene browser:
http://moi3d.com/2.0/docs/moi_command_reference11.htm#propertiespanel
http://moi3d.com/2.0/docs/moi_command_reference11.htm#scenebrowser
Basically colors are left to be used as a kind of grouping mechanism by your own preference, so there isn't anything like make all construction splines a particular color separate from the style system.
4587.13
sorry again!
another problem I have is:
I want to merge f.e. 3 separate faces.
I run the "merge"-command - the I selct the 3 faces -
and then "enter".
But after that, I still have these 3 faces sepeate.
thanks
Michael
4587.14 In reply to 4587.11
Well, you're not really doing anything wrong other than needing to get the whole thing joined together as one piece.
Sometimes seam curves can tend to get in the way and that's what's happening to you here.
With the pieces all joined together into 1 solid (see attached 3DM file), then fillet looks like it will be able to generate a partial result but it has difficulty trimming the objects back so the fillet piece that gets generated will have to be manually trimmed into place.
Let me know what fillet radius you want and I can help you do that.
Also the one main thing that would probably make it easier is if the midpoint of your shape was actually aligned to the seam instead of shifted just a little ways to one side - is that intentional that your top shape is not symmetrical around the center of the revolve?
By the way it's late over here so I'll probably have to continue tomorrow.
4587.15 In reply to 4587.13
> and then "enter".
Do you mean the Boolean merge command? The boolean commands are more for slicing up pieces that need to be intersected with one another.
If you have things that touch at common edges and don't need to be sliced up, then use the Edit > Join command rather than the boolean merge command to glue stuff like that together.
So probably in the case that you're describing there you would use Join, not boolean merge. If that's not right please post a 3DM file with your 3 surfaces in it so I can check them out.
Show messages: All  1-10  11-15
