Hi phunkidude,
> Is there a way to 'combine' the 5 objects into 1 so that
> when I export for Modo, I just have one layer in Modo?
Yes - select all the objects, and then assign them all the same name. You assign a name by clicking on the name line in the object properties panel:
http://moi3d.com/2.0/docs/moi_command_reference11.htm#propertiespanel
Then make sure you have the "Combine same named objects" checkbox enabled under Options > Import/Export, it's at the very top of the dialog.
When "Combine same named objects" is checked, objects that share the same name will be exported to a single combined mesh object when doing an OBJ or LWO export. Use LWO format for going into Modo.
