object world coordinates
All  1-4  5-6
4090.5
Hi Pilou and Michael,
Thank you for your replies, both of which solved my question.
The reason I asked was that I needed to place a cylinder in an exact position on a clock back plate to 'drill' a hole.
re OWC: I understand the problem now Michael. I was of course only thinking of my particular problem. And also thanks for the explanation, very clear and succinct.
I also have to say I am most impressed with MoI3D, in particular, I needed to use imperial measurements and it was a delight to be able too enter 3/16" (for example) as a distance, rather than converting it to pixels, mm or units first.
regards,
Mark.
4090.6 In reply to 4090.5
Thanks Mark, I'm glad that you like MoI!
Also one note about placing cylinders - if you need to place a cylinder on to a surface and the cylinder is not currently pointing in the same direction you need you can use the Transform > Orient command to do that which basically like a move + rotate combined together.
There's some more info on Orient here:
http://moi3d.com/2.0/docs/moi_command_reference8.htm#orient
http://moi3d.com/forum/index.php?webtag=MOI&msg=3424.13
http://moi3d.com/forum/index.php?webtag=MOI&msg=3424.14
And here's a demo of what that process looks like in action:
Show messages: All  1-4  5-6
