Remove Save (etc.) from right-click repeat?
3674.1
Is there any reason why the Save command (and other similar commands) are included in the right-click repeat last command function?
Not a huge deal or anything, but I'm just wondering if anyone ever repeats a save command via right-clicking?
Seems to get in the way and be a bit of a nuisance sometimes :)
3674.2 In reply to 3674.1
Edit the moi-ini file:-
[Commands]
NonrepeatingCommands=
Add the commands you do not want to repeat.
3674.3 In reply to 3674.2
Thanks Steve, didn't know that could be done.
Mark
Mark
http://www.homepages.ihug.com.au/~mabrown/index.html
3674.4 In reply to 3674.3
Hi Mark,
By default the entry in the moi-ini file is:-
NonRepeatingCommands=delete undo redo
you can just add other commands to that list.
3674.5 In reply to 3674.4
There are hidden commands in that list by default also....Like:
Crash
BadGeometry
Frustration
It's quite a large list!!!! :o
3674.6
Hehe this is good to know :)
I wonder what other commands I don't want in that list...
Cut/Copy/Paste, probably, too...
Save/Load/etc.
How can I find out their exact command names?
3674.7 In reply to 3674.6
Hi NightCabbage, there is a list of all command names here:
http://moi3d.com/2.0/docs/moi_command_reference11.htm#shortcutkeys
3674.8
Does this look like a reasonable list?
NonRepeatingCommands=delete undo redo new open opentemplate save saveas incrementalsave copy copyclipboard copyclipboardwithorigin cut paste pastepart export import importpart
3674.9 In reply to 3674.8
Hi NightCabbage, if it works for you then go for it! :)
Some of those could potentially be problematic as a default setting for MoI, for example being able to repeat import could be useful if you want to import a few different times in a row.
But if you find it getting in your way more often then you should add it to that list, I made that list customizable so that you are able to tweak this behavior to whatever works best for you.
