Some suggestions for future MOI versions ;)
All  1-4  5-12
3539.5 In reply to 3539.4
Hi vinced,
> 1.)What about
> a)The box ? That should work , shouldn`t it?
Yeah, but most of the time you would want to create models more complex than a box. If I only add features that work on a box it doesn't do a whole lot of good overall.
But actually I do want to add some stuff in the future to enable you to move faces and edges around, but it is not something that is easily set up with NURBS because it requires stuff like extending surfaces and modifying trimming boundaries. It's not like polygons where you can just jiggle the points of the polygons around and have things stay connected automatically.
There is another CAD program called SpaceClaim (http://spaceclaim.com/) which has done a lot of work to edit NURBS models in that way of pushing and pulling faces around. You might check that out if you want to work with that kind of method right now with NURBS models.
> b.)the cylinder? Why doesn`t it have control points?
That's because the top cap is a trimmed plane and not a "naturally trimmed" surface.
This is described in that FAQ answer I linked to above:
   Why does show points work for some objects but not others?
> Wouldn`t it be possible to scale the upper part to get something
> like a cone even with nurbs?
Yeah, that is possibly currently by using Edit > Separate to break the cylinder into individual surfaces, then you would probably want to delete the top cap, and now with the surfaces as individual objects instead of joined together you can use Edit > Show Pts to turn on the cylinder surface's points and select the top ring of points and scale them down.
Let me know if you would like some illustrated steps on how to do that.
> 3.) freeform curves:
> Is it possible to edit them and have the points on the
> curve and not control points?
There is not any way to do this currently, but it is something that I want to add in the future. It may not come until there is some kind of general history editing mechanism in place where you would be able to edit the original points you picked when drawing any object. But we'll see, if that takes too long I may make a special case just for "curve through points".
> Another thing. Are there some great tutorials for MOI,
> not necessarily for beginners. Tutorials that show the workflow
> of a pro CAD-user with MOI.
There are several links on the "Resources" page which has a link on the main web site:
http://moi3d.com/wiki/Resources#Tutorials
Check out Steph's videos, Daniele's lamp video, lyes Ferrari video, etc...
You also might try searching over the web for Rhino tutorials as well.
3539.6 In reply to 3539.5
Michael, that`s what i like about you, that you don`t simply say it`s not possible, but that you really think about it .
“But actually I do want to add some stuff in the future to enable you to move faces and edges around”
That is what I want to hear ;). I don`t care if it comes in MOI 5 or 6 as long as you try to implement it.
I am sure that Nurbs are the future of modeling. The only thing they lack at the moment are the advantages of Polymodeling like fast tweaking of faces and edges ect.
By the way the videos they show on spaceclaim are really magnificent. This is the way to go.
Even if we get only some of these features in MOI at some point in the future.
vinced
3539.7 In reply to 3539.6
Hi vinced,
Well definitely NURBS are great for mechanical and man-made type shapes. Those kinds of things tend to have lots of holes and cut out portions, and the way that NURBS booleans work is very nice for any kind of cutting or slicing.
Poly modeling is better for more organic shapes like creatures, faces, characters, stuff like that, where tweaking and sculpting things is more important than cutting or slicing.
There is a lot of variety between different kinds of 3D models. Some kinds of models are easiest with one kind of an approach, and other kinds of models work better with a different kind of technology or modeling method.
3539.8 In reply to 3539.5
>>is some kind of general history editing mechanism in >>place
>>I may make a special case just for "curve >>through points".
I would find "curve >>through points" very useful. Any chance for V3 Michael?
Mark
Mark
http://www.homepages.ihug.com.au/~mabrown/index.html
3539.9 In reply to 3539.8
Hi Mark,
Yeah, there's certainly a chance! It's too early yet for me to be able to make any promises about what will be or won't be in v3 though.
3539.10 In reply to 3539.7
"Poly modeling is better for more organic shapes like creatures, faces, characters, stuff like that, where tweaking and sculpting things is more important than cutting or slicing."
For now i agree, but nothing is impossible, isn`t it? You could do the base shape in a nurbsmodeller and then maybe do your detailing on some kind of second layer which is afterwards transformed into a displacement and normalmap.
The great advantage of nurbs is that you don`t have to mess around with a polygonmesh. You can create it after modelling. But in the end to replace polygon-modellers it`s all about tweaking faces, edges and vertices not necessarily on a polygon-basis.
Spaceclaim shows what is possible, but i think it`s only the first of several steps into this direction.
Only my two cents. Don`t really have the knowledge to give an accurat judgement, but my feelings say ->this is the way.... ;-)
3539.11 In reply to 3539.10
Hi vinced,
Well, I'm not so sure about that - it may be actually impossible to combine every single conceivable modeling technique and tool into one single interface and still keep it as something that is simple and easy to use.
When you refer to putting stuff on a displacement map on a second layer, do you mean that is something that you'd expect to do all within MoI?
Unfortunately it is very difficult to jam in a zillion features into one program without making the program complex and hard to learn...
In a lot of ways it can help a tool like MoI to be easier to use when it is more focused on solving some particular kinds of modeling problems really well instead of trying to do everything.
Of course I do want to add stuff to MoI to make it do more stuff in the future as well, but that's a pretty tall order to focus on doing every single possible kind of model all in one tool...
EDITED: 16 May 2010 by MICHAEL GIBSON
3539.12 In reply to 3539.11
No that was meant in general not a feature request for MOI ;-)
Show messages: All  1-4  5-12
