Llittle Surf headache
 1-4  5-24  25-33
I have a trouble: how do you make the the curvated surface after make the "flatten" curves and offtseted them?
I miss something :) A simple extrude and use old curves?
3158.26 In reply to 3158.25
That's by doing an "Untrim" on one of the original surface pieces.
Take one of the original curved surfaces, delete all the other ones, use Edit/Separate so you are dealing with just a single surface.
Now select all the edges, and hit delete to remove them and recover the full underlying surface - that's how I got back the original larger curved surface to trim.
The original is wide enough in one direction to cover the new larger outline, but not in the other direction where I added the lines.
EDITED: 9 Dec 2009 by MICHAEL GIBSON
3158.27 In reply to 3158.24
> Yes but it's a line and not a curve? no problem for a close up but in theory?
It's only a problem in theory if you want some other shape than a straight extension there...
You would need to know what the intent is of the extended shape - should it extend in a straight way from the current one? If so then a line would be the correct shape for that because a line is straight.
Just because it is a line does not mean that it is automatically bad for all cases.
It would probably not be quite as good if it was a polished mirror or something reflective like that but that does not look to be this particular case. In reflective objects things like lines tend to be more visible to the eye.
> Function Extend make the same ? add a tangent line to a curve
> from last 2 points of the a curve?
Yeah, same as what extend will currently do.
For just placing a line I usually just draw a line and use Straight snap to lock on to the tangent line.
3158.28 In reply to 3158.24
> For have the original I must cut incline ;)
So yes, go ahead and cut it then! :)
There is no rule that you must only accept the result of an extrude and cannot modify it by cutting.
It cutting is necessary, then draw a line and cut it...
> But you agree all that don't arrive if original generator were keept!
Yes, not without an additional cut - that means to draw a line in and do a boolean difference to slice it at the angle you want.
I'm not entirely sure if the actual desired shape is an extrusion with a cut end though, or a shell with a cut end.
Normally to get constant thickness you use shell, but since this is not heavily curved the difference is pretty small for this case.
< Now select all the edges, and hit delete to remove them and recover the full underlying surface - that's how I got back the original larger curved surface to trim.
that's this! I have tollally missed this paradigmatic thing!!! It's an Earthquake for me! :)
From what comes the measure of the length? I have only half of the form!
EDITED: 10 Dec 2009 by PILOU
A process ;) Flatten must be made in FRONT FACE !!! (and reading begin by the Bottom to Top sorry :)
@Michael : I don't use the extrude method in case where all sides should be inclined (so to much cuts)
As I obtain 2 surfaces I can easily make a sweep 2 rail between them even inclinations :)
3158.31 In reply to 3158.2
>Then go to the Front view and use the edit frame to flatten them down to be planar
Wow, how did I miss this feature of the edit frame? Another example of MoI's understated brilliance. :-)
Jesse
3158.32 In reply to 3158.29
Yeah it's one of the big differences with NURBS as compared to polygon modeling - NURBS can have Trim curves that trim away parts of an "underlying surface".
There's some more description of this here:
http://moi3d.com/wiki/FAQ#Q:_Why_does_show_points_work_for_some_objects_but_not_others.3F
It just comes from whatever was the original surface before it was trimmed or booleaned.
So in this case for some reason the original full surface was trimmed by only half of the curve outline, so when removing the trims it restores the original full part, which is convenient for this case.
3158.33 In reply to 3158.32
yeap I have translated that but don't yet make a connection with a concret case! ;)
Now that is done :)
I believe that an another method with sweep with 2 rails can also works : just drawing good angular sections at each direction change
Show messages:  1-4  5-24  25-33
