shotcuts
1819.1
Hello everybody
I am so used to shotcuts in AutoCAD so I needed it in MOI
I discovered it is very easy in case if you do not know.
Options box/shortcut keys
L for Line
M for Move
C for Copy
P for Polyline
S for Sweep
J for Join
T for Trim
E for Extend
So now it is enough just to hit L and I can start line so there is no more need to switch menus all the time especially for Move, Line, Copy
Thank you, Michael, for this great and easy option.
What is the command for arc 3 pts and circle certer?
I tried
script:3pts;
- did not work
Olga
EDITED: 26 Jul 2008 by MALVIN
1819.2 In reply to 1819.1
Hi Olga, I'm glad that was easy for you to set up those shortcuts!
For arc through 3 points, use Arc3pt and for circle from center use Circle.
There is a list of all the command names here.
Also Petr's MoI page has a collection of a bunch of scripts that can be set up on a shortcut key to do different tasks.
