Feature or workflow?
All  1-7  8
1343.8 In reply to 1343.7
Hi xrok1,
> #1 where is this "Relocate cline"
It's covered in the help file under construction lines:
http://moi3d.com/1.0/docs/moi_command_reference10.htm#constructionlines
When you create a construction line, a little tag will appear above your mouse - click and hold down on it (keep the mouse button pressed down) for a second and that menu will pop up with a bunch of additional options to control the construction line.
> would the axis locking be posible with a quick script?
You should be able to get a lot of axis-locking type of functionality from the construction lines - for example the steps I showed above gives you the equivalent of a z lock.
The nice thing about the construction line method is that it isn't actually limited to just world axis directions - you can drag out a construction line between any 2 points to use any direction that you want. But at the same time straight snap will help you to get axis directions if you want.
> did you think of any tips for me when i get to the corner junction of my model?
That's definitely going to be tough - it is hard to branch when doing a contour slice type method.
You'll probably have to build some things as separate pieces and then cut some holes and add some blends to connect pieces together.
Show messages: All  1-7  8
