Sketchup exchange
 1-10  11-30  31-50  51-66
1244.51
boatstalker, you might want to try this. not sure if it will work but it seems promising. let us know;-)
http://www.freedesign-inc.com/products.html
1244.52 In reply to 1244.48
Hi Michael. I understand it is more complex than what i mentioned, it was just the minimum example of a simple object which could be exported from Moi and be ready for sds (or at least with minimal amounts of mesh refining)...
jonah
1244.53
Some thoughts.
>I have added Sketchup file I/O to the wiki wishlist.
I am a big fan of the rush/pull tool my self , www.sketchup.com, www.3dvia.com/shapeit, With Models Ready for Microsoft Virtual Earth , Oh yes lets keep Microsoft happy too, haha very funny.
But anyhow I see Moi as an professional app and not as an BART SIMSONS TOY, Don't get me wrong but I dot see any reason for a Moi/SUp/Moi link, (they should meet else were).
Moi has already reach the professional circles and that is were it should aim at. Modo, 3dsmax,SolidWorks, bunkspeed, Maxwell... users love it, even Rhino users ask help from Moi.
Yet Limited supported formats, the ones there ROCK.
>Well, if you buy it, it makes it more likely that I will be able to stay in business and eventually be able to handle your request instead of going out of business! :
I wish I had a huge Studio to fill it with Moi, but that is not the case, although my check is ready.
>Hi xrok1 - I do want to experiment with what you are describing in the future (direct drawing on to surfaces)
yes pls.+1
>http://www.wtools3d.com/swf/tutorials/RTboolean/RTboolean.html + Some cool tricks on Inserting Doors and Windows http://www.ilexsoft.com/highdesign/media.html + http://www.visualarq.com/
Yes to somethink like that, but Micheal we can do better.
1244.54 In reply to 1244.51
Hi XROK1
http://www.freedesign-inc.com/products.html <
Actually I already have FreeDimension ;-). As an organic free form modeling tool it is brilliant. Using it is pretty much like sculpting some kind of a digital clay or jelly. The concept it´s based on is equally brilliant (adaptive/dynamic polygon mesh surface interpolation between (2+n)-sided patches defined by interconnected freeform curves). FreeDimension is polygon mesh based and it is an excellent concept modeler, especially when it coms to free flowing shapes.
However, if you want to make precision "man made like objects" NURBS is the way to go and MoI´s unique brilliant user interface makes it the modeling application of choice.
P.s. FreeDimension has the ability to export NURBS if the iges exporter plugin is purchased, so FreeDimension + MoI might be a quite powerful combo in the hands of a skilled artist/designer.
Hope this helps.
All the best,
Boatstalker
EDITED: 12 Jan 2008 by BOATSTALKER
Message 1244.55 deleted 12 Jan 2008 by YANNADA
1244.56 In reply to 1244.54
If it has not been mentioned before,
Carrara6Pro (probably any version) just LOVES working with MoI stuff, especially in the Vertex(Poly) room.
I usually save as IGES files from MoI as it makes shading (shading domains) a breeze in Carrara.
Carrara6 Pro, MoI and 3D Brush (and PhotoshopCS3 Extended)
The only way to live!
1244.57 In reply to 1244.56
sounds complicated. me no like..
1244.58
I would also like to see some form of link between SketchUp and MoI, or some way of importing meshes into MoI. Naturally it would be nice if the imported meshes are converted to Nurbs on import, so you don’t have to think about the difference between the two types of objects. From the user perspective we shouldn’t even need to understand the difference between mesh, Nurbs, Sub-D, ESub, T-Splines etc. It should just be geometry, regardless of how the computer understands it. Maybe the Esub will really bridge that gap… Hopefully already in MoI 1.1 ;).
I just started to play with MoI a few days ago, and with my SketchUp skills I was directly able to model a nice ring. What I can’t do is cut diamonds, but I was able to find a brilliant cut in DXF. I would need that mesh in MoI to do the fitting.
I also have Rhino and T-Splines, got them just two days before discovering MoI :( . I can go from SketchUp in obj to T-Splies, and then convert to Nurbs, and then open the 3dm in MoI, but then I loose the sharp edges. Or can I convert to Nurbs some other way? I was thinking a Boolean union of a Nurbs box and the diamond mesh would do it, but doesn’t...
Copying as much of the SketchUp workflow and tools is another thing I second. The inferencing of directions, push/pull etc. Having all of that in MoI would be wonderful, but I know many of the tools are unfortunately patented. On the other hand I don’t think Google is interested in Nurbs, or even proper curves, so maybe they will let you use them for a small fee.
1244.59 In reply to 1244.58
Import your Sketchup file into Rhino
run command "MeshToNurb"
then run command "MergeAllFaces"
then Copy/Paste into Moi...
Also i don't think you can patent a feature of a software. You can only patent or copyright the software code. So this similar push/pull type of function can be found in other programs such as Alibre 10. and also Rhino can push/pull polysurface faces under the right conditions. I see no legal reason why Moi can't have a similar function...
jonah
1244.60 In reply to 1244.59
Thanks Jonah,
I was looking for that in all menus… but I now have my diamond in MoI.
Guess I still have a thing or two to learn in Rhino…
Sheik
1244.61 In reply to 1244.60
Hi Sheik, one difficulty with doing this automatically is that a diamond is kind of a special case, in that it is supposed to be made up of planar facets.
So a conversion from mesh to NURBS where each polygon becomes one facet works fine for this case.
But often times polygon mesh files are intended to be a simulation of a smooth surface instead of one with planar facets. Trying to convert one of these types of mesh files into a NURBS object where each polygon becomes one little tiny NURBS plane will not work very well. The NURBS structure expects smooth surfaces to be made up of larger smooth surface patches instead of tons of little facets.
1244.62 In reply to 1244.61
Well I decided to get MoI, even if I fear this decision will keep me from taking the time to learn to use Rhino. I guess I will be using Rhino only for things I can’t do in MoI, but actually I will still primarily be using SketchUp.
I can imagine turning a faceted mesh surface into a one smooth Nurbs surface will need some serious coding. I wouldn’t mind an easy solution, and make the mesh becomes a big bunch of faceted Nurbs patches. I would only want it for reference, and maybe some Booleans.
Rather new to the whole Nurbs world I still don’t know exactly what you can and can’t do with them. Some simple stuff surprises me like; I can select an edge or face of a simple box, but I can’t move or rotate it (like I can in SketchUp). Is that difficult to implement with Nurbs?
I actually suggested SketchUp would add “Jell-O-mode” to the transforms. It would be similar to “soft-selection” transforms in some modellers: move (or rotate or scale) the top of a box, then define a distance for how rigidly you want the rest of the geometry to follow, and shaping would be like playing with jello Everyone has played with jello, right? No need for separate transform commands. (Somehow I think this would be easier with Nurbs, as you would need to add and reduce faces for this in a poly-modeller)?
Adding edges, moving them and push/pulling the new faces is a very fast way of modelling, which I would eventually like to see becoming possible in MoI.
Add the possibility of turning some faces (or edges) to be curved (tangent, G1, G2 etc.), thus turning the original surfaces and edges to a control cage, you could do very powerful box modelling (similar to T-Splines).
Oops, I guess I was rambling for a moment there, but this is such an inspirational product.
KIS, and think of new ways of making modelling more fun!
1244.63 In reply to 1244.62
if you already have Rhino 4, then you can do many of your "Jell-O" transforms using Rhino's UDT functions. Also there are commands such as rotate face, scale edge, etc... This is not an easy thing to handle in Nurbs, because transforms will rip apart the seams in a polysurface. With polygons, transform functions don't have to worry about retrimming, tangency matching, and surface rebuilding as they do in Nurbs. Polygonal modelers just move vertices, which should be pretty easy. Nurbs require the object to be analyzed, rebuilt and redefined.
Also Tsplines is a great converter, but only for meshes that have a subd-friendly topology. If you try converting from Sketchup meshes, i imagine the results will not be what you hope for...
jonah
EDITED: 4 Feb 2008 by JBSHORTY
1244.64 In reply to 1244.62
Hi Sheik, thanks for deciding to get MoI, I hope you enjoy using it!
One other thing you can do for bringing in a mesh as a reference is to use this tool: http://moi3d.com/resources#Obj23dmWireframe_converter which will extract out all the edges of a polygon mesh OBJ file and put them as line curves in a new .3dm file. Then that .3dm file can be loaded in to MoI and you will be able to see the wireframe of your mesh object in MoI as a reference and snapping guide.
It is much more difficult. Often times in NURBS the edges you see are "trim edges" with a larger surface underneath them, which means that the surfaces that make up your model often don't have their points aligned at the shared edge. See this FAQ answer for some more explanation and illustration.
This structure basically means that you can't pull things around by their edges (except in the case where the surfaces are actually aligned and end naturally at a common edge), but it is also the same structure that makes NURBS work much better than polygons for booleans and cutting operations. When you do repeated cuts on a NURBS object, it keeps the same underlying surface as a single big sheet and just new trim curves are calculated.
For Jell-O type squishing like Jonah mentioned the best solution currently is to take your objects into Rhino v4 and perform the squishing in there. You can move objects back and forth between MoI and Rhino quickly by doing Copy and Paste between them.
1244.65
I just found this. SpaceClaim looks like SketchUp on Nurbs. I hope we will see something like this in MoI 2.0 ;).
http://www.spaceclaim.com/Resources/SpaceClaim-Videos/SpaceClaim-Demo.aspx
Sheik
1244.66 In reply to 1244.65
Hi Sheik,
Nope, probably not - it takes quite a bit of extra programming work to do this kind of "history free editing" type stuff.
It's also fairly specialized for mechanical design type work, and MoI is not as exclusively focused on mechanical part design only.
If you need those kinds of SpaceClaim-like functions, your best bet is to buy SpaceClaim to do those operations.
SpaceClaim has good support for the .3dm file format, so it should work well to use MoI in combination with SpaceClaim as well.
Show messages:  1-10  11-30  31-50  51-66
