Edges & Visuals
All  1-4  5-17
9958.5 In reply to 9958.4
Quick Edge Selections:
Styles Hide/Unhide + EnableSelectionSubTypes=y
edit 18th May 26, (giff on cdn).
EDITED: 18 May by LIGHTWAVE
9958.6 In reply to 9958.5
Hi Stefano, also if you select one edge on an object, then Ctrl+A (Select all) after that will select all edges of that one object and not other things.
9958.7 In reply to 9958.6
Thanks Michael that seems like something I totally overlooked! Stefano
9958.8 In reply to 9958.7
Hi Michael, is it possible to "select all" where it only picks the edges that span a z axis.
E.g. are vertical edges not horizontal ones.Might be 16 of them on a frame solid as shown...
2x4 inside edges, and 2x4 outside edges.
one potential way is suggested e.g. via selecting 1st one then using object properties to find
others. script maybe is the other..
EDITED: 22 Sep 2020 by LIGHTWAVE
Size: 332.5 KB, Downloaded: 67 times, Dimensions: 1050x594px
Size: 159.5 KB, Downloaded: 46 times, Dimensions: 675x498px
9958.9 In reply to 9958.8
You have something who select by Length
Change dimensions min, max as you want...
script: /* Select by Length */ var min = 1.0, max = 5.0; var crvs = moi.geometryDatabase.getObjects().getCurves(); for ( var i = 0; i < crvs.length; ++i ) { var crv = crvs.item(i); var len = crv.getLength(); if ( len>= min && len <= max ) { crv.selected = true; } }
and this one
change size = as you wish...
script: /* Select Smaller Than given Length */ var size = 1.0; var objs = moi.geometryDatabase.getObjects(); for ( var i = 0; i < objs.length; ++i ) { var obj = objs.item(i); var bbox = obj.getBoundingBox(); if ( bbox.diagonalLength < size ) obj.selected = true; }
EDITED: 22 Sep 2020 by PILOU
9958.10
http://moi3d.com/wiki/V4Beta
crv.isLine
only this condition + direction - start learning scripting xD
- Tudor -
9958.11 In reply to 9958.9
Thanks Pilou, if the lengths changing I have to likely get the min and max to cover everything.
will give it a try. If the designs get a bit more standard this could be good. -Stefano
@Tudor pretty powerful this scripting stuff.
I might know the logic or requirement....
1. If line is on xy fixed position and z points is variable, select, otherwise no selecto.
Or
2. If line is xy variable and z point fixed select, otherwise no selecto.
The best way of implementing this is I think to select the 1st line or edge 1st.
So the script has a cheksum right there "if line selected = 1 or 2" select others like it
1 selects vertical lines (edges)
2 selects horizontal lines (edges)
Excuse my basic knowledge of programming. I have miles to go!
I like sound of this one ...
crv.isOnPlane could that be used maybe to select lines as indicated?
> I dont think this is easy <
Reference the image attached I am trying to find a 'one click' way...
the script would need to select the EDGES on the external
and after that the inner edges would need to be done seperately.
these selection methods dont seem to work as you are crossing other
areas with other edges that dont need to be selected.
http://moi3d.com/forum/lmessages.php?webtag=MOI&msg=8905.19
'wireframe mode' is easiest for manual selection i find.
Size: 164.2 KB, Downloaded: 42 times, Dimensions: 774x371px
Size: 146 KB, Downloaded: 29 times, Dimensions: 1338x715px
9958.12 In reply to 9958.8
Hi Stefano,
You can do a crossing window selection to do that, select one edge then drag the window from right towards the left through the middle of the object:
9958.13 In reply to 9958.12
I could have likely explained this better! Anyhows, the manual selection is admittedly very fast and the learning goes on...
the issue i am finding is I will be selecting other objects usually on drag selecting. Then its another de-selection.
I'd be interested to know if all the colours I am showing as 'EDGE selection groups' in this video
could actually be 'identified' by a script. Ideally, few click solution.
-Stefano
9958.14 In reply to 9958.13
Hi Stefano,
You can solve this by hiding the other objects so only the one you need to work with currently is visible.
A quick way to do that is to select your object of interest and then right-click on the Edit > Hide button. That will trigger the "Isolate" function which will hide other objects and only leave the selected one showing. When you're done right-click on Edit > Hide again and things will return to the same visibility state as before the isolate.
So you mean the vertical lines but only the ones on the outermost surfaces? Right now I can't really see an easy way to identify those using script.
I would recommend using 2 window selections like you show.
9958.15 In reply to 9958.14
>> Will start using that for sure.
>> Yes in this instance it would be like this picture shows.
I would recommend using 2 window selections like you show [ + 'wireframe' + spellcheck ]
- Stefano
edit: 15th May 26, squashed image, nothing new here.
EDITED: 16 May by LIGHTWAVE
9958.16 In reply to 9958.15
Hi Stefano, I guess if you had a center point to reference then in that case a script could evaluate the surface normal at say the midpoint of the edge and see whether that is pointing towards the center point or away from it.
9958.17 In reply to 9958.16
Hi Michael, as these are always regular shaped 'frames' I can presume there is always a "box" centre. It's good to know theres always a way.
Learnt a lot about manual selections on this one so likely i can already work 50% faster.... Originally selecting those inner verticals with solids in the way was 'fun' as I orbited around the contours. Thanks again - Stefano
> Wireframe Shortcut Script:
script:var breps = moi.geometryDatabase.getObjects().getBReps(); var hide = true; for ( var i = 0; i < breps.length; ++i ) { var faces = breps.item(i).getFaces(); if ( i == 0 ) hide = !faces.item(0).hidden; faces.setProperty( 'hidden', hide ); }
Others of interest here:
http://kyticka.webzdarma.cz/3d/moi/#ShadedDisplayMode
Will be trying this 'adjacent edge' loop script also...ref Michael post
# 3112.22
script: /* Loop selection */ moi.geometryDatabase.selectLoop();
EDITED: 28 Sep 2020 by LIGHTWAVE
Show messages: All  1-4  5-17
