Dimensions Feedback and Features
All  1-6  7-14
9950.7 In reply to 9950.6
My favourite reference page to Max's dimension script,here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=7403.41
Hi Pilou, as someone new to MOI I'm currently more curious to test ins and outs of native functions 1st...
Especially interested in the new features (dxf layers, annotations etc) as it gives us chance to test and contribute other ideas. Of course later on I'll likely test or use other tools - node editor, customui etc etc. Right now its plain v4 nothing else allowed to distract me..
Oh talking of learning, 》》》watch out 《《《 I got that gif screen tool installed and 1st one is up there :0)
Great forum ...your contributions are greatly respected!!!
Stefano
EDITED: 17 Sep 2020 by LIGHTWAVE
9950.8 In reply to 9950.7
No problem! :)
9950.9 In reply to 9950.8
Fyi: I've also been to your website a few times and liked its organisation.. have a lot of Max's tools shortlisted for later.
I had a slight headache with the custom ui and then when the latest beta came out I said....
"stick to standard" (for a bit)
Ps. The best dimension on any production drawing I might do is often a 10x10mm reference block.
Less is more.
9950.10 In reply to 9950.9
Custom Call Outs / Leaders
> Left click to draw points.
> Right click to end.
> I leave text blank here to manually position text precisely afterwards.
Notes:
- Nice there is an annotations type layer split by 'type'
- Feature Request - Ability to link text to object in more flexible way.
- Feature Request - Ability for sequential callout/leader numbering (with incremental start control)
- Feature Request - Bezier control and/or way to convert other lines and curves to object type:-leaders.
EDITED: 18 May by LIGHTWAVE
Size: 6.9 MB, Downloaded: 694 times, Dimensions: 1395x739px
9950.11 In reply to 9950.10
EMAIL AN ORDER | WORKFLOW EXAMPLE
__________________________________________________________________________
> Using all native annotation tools + style colours to draw attention to small details.
> This workflow uses a couple of 'smart' shortcuts kindly provided by Michael.
> Uses my favourite 'lightweight' screencapture tool 'PrtScr'
http://www.fiastarta.com/PrtScr/
> Text file called "MOI3D ANNOTATIONS R0" has further info and the settings I use (below).
EDITED: 18 Sep 2020 by LIGHTWAVE
9950.12 In reply to 9950.11
RTF FILE has a few shortcuts, tips and screenshots that may help
people save a lot of time if working with annotations or looking to email
'marked up' drawings.
Can't help mac users on screenshot software but nonetheless
most can work this out and just take the shortcuts and also see:
Other ways to take screenshots from viewports here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=9526.173
http://moi3d.com/forum/index.php?webtag=MOI&msg=4559.2
Attached is the basic moi file used for the demo...
UPDATE: R1
As I prefer to use a universal screen capture tool...Here's the final script I am now using prior to taking the screenshot(s)...
script: /* Toggle show grid and axis and colour*/ moi.grid.showXYAxes = !moi.grid.showXYAxes; moi.grid.display = moi.grid.showXYAxes; if ( !moi.grid.showXYAxes ) { moi.command.setOption( 'prev_bkgnd_color', moi.view.viewportBackgroundColor ); moi.view.viewportBackgroundColor = 0xFFFFFF; } else { var prev_background = 0xd0d5da; try { prev_background = moi.command.getOption( 'prev_bkgnd_color' ); } catch(e){} moi.view.viewportBackgroundColor = prev_background; }
Translated:
A. Toggles off Grid and grid axis
B. Makes background white
THEN...press 2:
C. Toggles back on grid parts (A) and.... goes back to previous background colour.
The script stores the previous color value somewhere else rather than as just a local variable inside the script. There is a method meant for storing command options between runs of a command.
But it will only store it for this program run, it won’t persist between program sessions. So try to remember to restore it before you close down MoI. If it cannot find a saved value it
will use #d0d5da [default grey] .
Thank you Michael !!!
COMING SOON/NEXT:
Demo on Workflows for Presets etc.
EDITED: 21 Sep 2020 by LIGHTWAVE
9950.13 In reply to 9950.12
Shortcuts kindly provided by Michael that help speed up / automate creation or management of dimension presets.
#1: Goes direct to ADD DIMENSION PRESET
script: /* Add preset dialog */ var dlg = moi.ui.createDialog( 'AddPreset.htm', 'resizeable,defaultWidth:26em,fixedHeight'); var res = dlg.window.doModal(); if ( res != -1 ) { var name = res[0]; var copy_from_index = res[1]; moi.geometryDatabase.addAnnotationPreset( name, copy_from_index ); }
#2: Goes direct to Options/Dimensions
script: /* Options dialog - dimensions */ moi.command.setOption( 'Options.htm_lastused', 'Dimensions' ); moi.ui.createDialog( 'Options.htm', 'resizeable,defaultWidth:43em,defaultHeight:32em' )
#3 Stefano 'shorthand' one for opening options dialogue box:
moi.ui.createDialog( 'moi://ui/options.htm','resizeable,default');
or
script: /* Options */ moi.ui.createDialog( 'moi://ui/options.htm','resizeable,default');
9950.14 In reply to 9950.13
When more than one object is selected or all objects selected its easy to get the annotation selections
Just click "details" or use a shortcut for object properties (as above post 9950.4):
nothing new here @ 18th May 26.
asides first post had rather large .giff, now on our cdn.
Show messages: All  1-6  7-14
