Little trick challenge :)
All  1-3  4-7
After a boolean cutting, inset is not a so bad idea.
You could "inset" two or three faces of a solid together to avoid part of the corner problem you had.
For external corner you select together 3 faces, for external egdes, 2 faces and top internal face only one.
Perhaps another way is
-- Copy/paste original solid
-- a boolean cutting with lines
-- explodemove function on cutted solids
-- your copy is inner solid and have to be resized
The problem is : with ExplodeMove you don't have spaces not so regular.
EDITED: 12 Sep 2020 by PHIRO
Size: 245.9 KB, Downloaded: 19 times, Dimensions: 601x401px
Size: 291.9 KB, Downloaded: 25 times, Dimensions: 652x399px
9945.6 In reply to 9945.5
Very cool variations!
The ExplodeMove was a very tricky try! (maybe also with Scale and/or Orient / Line Line )
Here ExplodeMove + Scale with your trick of second copy Volume! :)
Render : Free CADRays + Old Free Fotor
All funny of that is that made in a half minute! :)
Curious : Vertical Fatlines inclined (or not) must be rotated!
EDITED: 13 Sep 2020 by PILOU
<< The problem is : with ExplodeMove you don't have spaces not so regular.
Maybe we can use Align / Distribute! ;)
http://moi3d.com/forum/index.php?webtag=MOI&msg=8503.17
Show messages: All  1-3  4-7
