edit 15th May 26 Squashed an image, nothing new here.
Hi Michael & Everyone,
The attached moi-file deploys V4 Beta "DXF import layers".
The artwork should be seen as positional. What results
especially once i create better 3D model(s) will be
an original 3d layout visual.
'Challenge'
1. There is 96pcs 2d shapes on a RED layer and these are just "2D [XY] Component Positions".
I picked a square, but i could give you a cross-hatch a circle or whatever might work best.
2. All 96pcs of those 2d shapes will be swapped out or simply used as XY reference points.
3. We then have the "3d Swap reference part" from the GREY layer...
4. The reference part needs to magically appear on the GREEN layer (96pcs).
Other notes:
>Once the 3d components are swapped out and in place, the shape outline on the white layer
will get a 'fill' and become "3d" or planar itself. Its just a flat metal panel with material thickness 2mm.
The 3d shapes will be placed on the top surface of this surface. Later they are likely to be 'joined'
or 'holes'.
> I deliberately put one shape out of grid so please don't suggest i do all this in
MOI with 'array' ;o). This looks linear but later it will likely be very far from that.
> Red layers are only ever reference and don't ever get deleted but likewise they
dont end up on final 'visuals' either.
Interested to see magic happen!
Manually done:
