Script naked edges > script naked curves ?
 1-6  7-25
9869.7 In reply to 9869.6
Hi RJ,
> Is there a parameter available in MOI that tells the system how far from the current cursor position the
> system should "look" to find a line (or especially the end of a line) to "snap" to?
Yes, it's a setting under Options > Snaps > "Snap radius":
9869.8 In reply to 9869.5
Hi Tom,
> <end & start match another end or start or pt on curve - as i've undestood>
The "pt on curve" part is probably more difficult. I could cook up something that just looked for endpoints matching if that would be useful.
9869.9 In reply to 9869.8
>The "pt on curve" part is probably more difficult.<
Thats what I thought.>I could cook up something that just looked for endpoints matching if that would be useful.<
It would be a great time saver !
Would it be possible to cook it up in a way to select a whole bunch
of curves and MOI signaling which nodes of curves do not match exactly ?
9869.10 In reply to 9869.9
Hi Tom, it could generate a point object at endpoints that did not have a match, would be good?
9869.11 In reply to 9869.10
How would that point object appear - in selection mode as to
be easily distinguishable ?
Have I understood right : the follwing is makeable :
- Selection of a bunch of curves with "node" points where their ends should match perfectly (like attached example)
- Run script
- AOne or more point objects appear clearly visible there, where the curve ends do not match perfectly
Sounds amazing and would be a lovely time saver tool !
EDITED: 9 Jul 2020 by SIRTOM
9869.12 In reply to 9869.11
Hi Tom, it would just appear as a regular point object does like if you create one under Draw curve > More > Point.
That would behave similar to MarkCurveStart:
http://moi3d.com/forum/index.php?webtag=MOI&msg=5288.21
9869.13 In reply to 9869.12
Looks perfect for me.
If alle the points of the curves are deselected,
the appearimg points will be clearly visible.
9869.14 In reply to 9869.13
Hi Tom, give the attached script a try.
9869.15 In reply to 9869.14
WOW - fabulous !!
Michael, your attitude towards your userbase is as
exceptional as your phenomenal software.
My respect to you and once again :
*** Thank you so much !! ***
9869.16
Working with it now and enjoying the heavy decrease in necessary
clicks to create the desired shapes :-)
9869.17
I asked for something like this some time back. One of the most troubling aspects of MOI is, what I call, spurious endpoints. This includes "intersections". If I am zoomed out to a reasonable level for the modeling in progress, I may try to pick an Endpoint, but there may be two or even several points that might be chosen because they are very close together -- but not the same point. And choosing the wrong point has consequences. I move the cursor around a point and watch the coordinates to see if they change slightly. In some cases it may only be that the change is 0.001-unit. To make certain that I'm getting the right point, I must continually zoom in close enough to see what is going on. I understand that, to some extent, these things are unavoidable, but there just seem to be too many "points" that come out of nowhere and create ambiguity. Given what I've said, the trouble with trying to fix these things is that the program would have to first identify which point is the right one! Michael also told me that there is the issue of tolerance: How close together is close enough to be considered part of a problem that needs to be corrected? What might be a more practical option would be to get a "red flag" if we choose a point, and there are other possibilities 'near by' (whatever that means). If there is no red flag warning, then we would know that we had a good point. With a red flag, we would know to zoom in and check what is going on. As it is, we often have too many choices and it is very easy to pick the wrong one if we are not very diligent. I think that trying to fix these things after-the-fact is a can of worms.
9869.18
I'm sorry, I must be terribly dense. Well, actually, just trying to wrap my head around the procedures in MOI. I can't figure out how to use that nifty plug-in.
I drew a couple of lines on one plane, and then activated the plug in to MarkUnmatchedCurveEnds, but I couldn't see anything happen on the drawing. I could click on the lines and they turned yellow, but nothing else. Didn't matter if they intersected or not.
When I launched the plug-in, an information box popped up in the upper right, which SEEMED to be asking for an input (i.e. "Tolerance") but I couldn't figure out how to use that box. No amount of clicking anywhere in that box did anything.
And then the computer "hung" for half a minute... I was almost ready to do a hard reboot when it finally came back.
Michael, you have my great respect. You obviously know the API for MOI inside and out; I looked at the JavaScript and although I don't understand it, it's obviously a masterpiece of object-oriented programming. Are you one of the developers of MOI?
If it matters, my computer is running Windows 10.
9869.19 In reply to 9869.18
Normally you have that...
9869.20
u'r commad ui looks weird, it should be an input box(css problem)
about tolerance
(1/3)*3 != 1 -> there will be a margin error - tolerance is that margin error after all moi curve's calculations
- Tudor -
9869.21 In reply to 9869.17
Tim,
I dont know how to solve your issue but you seem to be in
need to often zoom in at point level.
There is a script from Michael which is helpful to zoom in
quickly to point level with just one keystroke.
Does not solve your problem but speeds up the process
of zoomng in.
9869.22 In reply to 9869.21
Jay,
So you have a bunch of curves whose ends meet at one or several shared common points -
you can download the example I attached at the beginning of the thread.
Now you select them all.
Run the script.
One or more points will be created by the script command where the curve ends
do not match perfectly. Thats it.
You can turn on select points to get them in the yellow color to make
them easier to identify
9869.23 In reply to 9869.20
Yes, Cemortan_Tudor, I agree it's a UI problem.
I notice the script uses HTM and JS. Does that mean it actually depends on my browser? If so, maybe there's a browser setting I need to change?
9869.24 In reply to 9869.18
Hi Jay,
re: Can't run script - what version of MoI are you using? It looks like you may be using version 2? If so then that's the problem, that version is really old. It was released more than 10 years ago. You would need to update to the current version to run this script.
Yup!
9869.25 In reply to 9869.24
Michael, you are a genius. Yes, I'm on Version 2. I have sent a query to Alibre to see if an upgrade to V3 is included in my Alibre subscription.
-RJ
Show messages:  1-6  7-25
