Turning joined surfaces into a solid.
All  1-2  3-5
9865.3 In reply to 9865.1
Hi Gord, also some of the naked edges are very tiny, those may be difficult to see when they are selected. There is a plug-in here that can help with that, it creates a point object at the start of selected curves:
http://moi3d.com/forum/index.php?webtag=MOI&msg=5288.21
But even after naked edges are patched up you still may have some problems if you try to do a boolean that cuts through an areas with little tiny microstructures in it.
You have absolutly no Name By Object, no selection by Color...that don't help for Hide something!
Else Michael was so speed :)
9865.5 In reply to 9865.1
Hi Gord, I've attached a version here that has been tuned up to be a solid now. I did that by identifying the problem spots using the select naked edges and MarkCurveStart scripts as mentioned above. There were a couple areas where a hole just needed to be filled in using either Network or Loft, but there were also some spots where an edge had gotten compressed down to a single point and those are more difficult to deal with. It's a pretty tricky process that involves untrimming surfaces around problem areas and then retrimming them. There is an object repair tutorial here if you want some more details:
http://moi3d.com/forum/index.php?webtag=MOI&msg=446.17
3DM file is attached. I think you should be ok to do booleans on it now:
You may run into some problems if the boolean tries to cut through an area that has some of the tiny slivery pieces, like probably a cut that has to make an intersection through this area may be difficult to do:
Hope this helps though!
Show messages: All  1-2  3-5
