Moi3D - KitBash addon
All  1  2-8
9805.2 In reply to 9805.1
Hi Andrew, that is using the Object Library plugin from Max Smirnov which is a part of the CustomUI extension. You can get it at:
http://moi3d.com/forum/index.php?webtag=MOI&msg=6507.1
> Another thing is, will this script work in Moi v4? I dont want to get used to it, and then choose beetwen
> older version of software or do not having this great addon.
Yes, there is a version of CustomUI that works with MoI v4.
> The last thing is, that after all this years Moi should have a clean webpage with
> list of all usefull scripts, documentions etc.
If you go to the "Resources" link on the main web page, there are links to collections of the most frequently used scripts here:
I do want to make it easier to browse and install script in the future, I have some ideas on having a script browser that you would pull up in MoI that would connect to an online script repository. It will be quite a lot of work to make that though so I'm not sure when it will happen.
EDITED: 13 May 2020 by MICHAEL GIBSON
9805.3
Hi Andrew
Before there was KIT OPS, I used Max's excellent plugin to add kitbashing to MoI for myself:
Unfortunately, that website is no longer available ever since Dropbox killed their public linking. But I'm sure you can see it is possible.
9805.4
Well, maybe that link does work! I must've converted it :-)
https://altuit.cloud/web/markdown/MoiObjLibDontMove/mdwiki.html#!index.md
9805.5
Thanks guys!
Thanks to you it brightened up a bit :) Although I am still looking around with curiosity at all these "magic" plugins for Blender. It seems that thanks to them you can really speed up your workflow. Plus, easy installation and great documentation are definitely advantages. I have to figure it out somehow, which will be better for me :)
9805.6
Hi all - so sorry for reviving this old thread!
I've been searching everywhere but can't seem to track down the script/add-on for this kitbashing kit. If anyone happens to have it and would be kind enough to share, I'd really appreciate it.
I'm also on the lookout for a solid, working video tutorial on how to use it properly. Most of what I've found so far seems to be outdated or the links are dead.
Thanks so much in advance for any pointers!
9805.7 In reply to 9805.6
This one by Chipp Walters ?
https://moiscript.weebly.com/kitbash.html
Seems all is explained ;)
In French but there are some pages translater! ;) https://translate.google.fr/?hl=fr&sl=en&tl=fr&op=websites
And you have all separated objects in one file! ;)
You will find the Custom UI by Max Smirnov on the top of this page!
https://moi3d.com/wiki/MaxScriptArchive
EDITED: 27 Jul by PILOU
9805.8 In reply to 9805.7
Thanks a lot, Pilou!
Show messages: All  1  2-8
