Is there a feature to 'plug' geometry on surfaces?
All  1  2-11
9778.2 In reply to 9778.1
Additional Question: Is there a 'symmetry' function that can automatically mirror changes on both mirrored sides?
9778.3 In reply to 9778.2
>>symmetry
Draw a box or any object
Mirror
Modify the original (Points : Move, Scale Rotation), (Global without Point : Move, Scale, Rotation)
About First question: See Chipp Walters! ;)
(sorry in French ;) http://moiscript.weebly.com/kitbash.html
EDITED: 26 Apr 2020 by PILOU
9778.4 In reply to 9778.1
Hi aphaits, there isn't anything built in for that but you can get that effect by doing a boolean and then doing a fillet after.
There is a mirror command that can be used with history updates like Pilou writes above but it's not quite the same thing as a live symmetry type function. I would like to work on a deeper symmetry function in the future.
PS Instance function for mutual modify (without the Mirror above) is a little tricky!
Draw Object A (here on the left)
Copy Move it as Object B
Select Object B !!!
Enable History !!!
Modify object A !!! ;)
9778.6 In reply to 9778.3
Very nice video reference!
Thank you, the logic clicked to me when Chipp describes it as substracting first then add kitbash.
9778.7 In reply to 9778.4
Thank you Michael for the reply.
Boolean and fillet seems ok for basic hole details.
Plugging the hole with extruding details seems to work fine. (from the widget kitbash Pilou posted)
The only missing logic that I'm looking for is applying it in curved surfaces.
Looking forward to future features!
9778.8 In reply to 9778.7
Hi aphaits, the Transform > Orient command can be good for placing an object aligned with a surface normal on a curved surface.
http://moi3d.com/3.0/docs/moi_command_reference8.htm#orient
http://moi3d.com/forum/index.php?webtag=MOI&msg=3424.13
http://moi3d.com/forum/index.php?webtag=MOI&msg=3424.14
Also if you have an object set up in its own separate file centered around the origin you can the ImportPart command which is available by a right-click on the File > Import button. That will bring in that file's content and place it like the Orient command.
9778.9 In reply to 9778.7
Or if you want to draw something aligned to a surface normal you can use View > CPlane to set the construction plane to that local frame of reference.
Or use the fabulous Orient / Line / Line...my favorite one! :)
9778.11 In reply to 9778.8
Not bad!
Need to play around with it to get it right, the orient command helps a lot!
Really useful for placing screw holes on 3d print models and adding details on scifi hard surface.
Awesome!
Thank you Michael and Pilou!
Show messages: All  1  2-11
