offset curve point
All  1-2  3-7
9771.3 In reply to 9771.2
points deleted manually
redraw your line with bezier handles
EDITED: 28 May 2020 by CORCHET
9771.4 In reply to 9771.1
Hi Tony,
> How can I avoid having so many points when offsetting a curve?
You can try the Rebuild command:
http://moi3d.com/3.0/docs/moi_command_reference10.htm#rebuild
But in general I would not recommend trying to edit the control points of an offset. Offset curves have a lot of points in them because the offset is generated by a fitting process. Just offsetting the control polygon of a curve does not yield an accurate offset curve, see here for an example:
http://moi3d.com/forum/index.php?webtag=MOI&msg=3838.23
9771.5 In reply to 9771.4
Thanks Michael ... you've been clear;)
9771.6 In reply to 9771.5
1st - draw your piece - offset - rebuild the 2 lines ( yellow lines ) - extrude
2nd - apply a large filet - copy paste the borders of the filets - and join them - now you have perfect parallel lines
3nd - draw a profil to sweep the 2 parallel lines - and the swep is ultra clean with same distance everywhere
9771.7 In reply to 9771.6
Thank you corchet :)
Show messages: All  1-2  3-7
