offset curve point
9771.1
How can I avoid having so many points when offsetting a curve?
Size: 537.9 KB, Downloaded: 23 times, Dimensions: 1600x1200px
9771.2 In reply to 9771.1
1st curves : polyline + filet .... few points
2nd curves : freeform ... a lot of points if you offset
3rd curves ... copies of the 2nd curevs and apply the script Rebuild ... few points
points can be deleted manually ... select a point and press Delete key on keyboard
EDITED: 28 May 2020 by CORCHET
9771.3 In reply to 9771.2
points deleted manually
redraw your line with bezier handles
9771.4 In reply to 9771.1
Hi Tony,
You can try the Rebuild command:
http://moi3d.com/3.0/docs/moi_command_reference10.htm#rebuild
But in general I would not recommend trying to edit the control points of an offset. Offset curves have a lot of points in them because the offset is generated by a fitting process. Just offsetting the control polygon of a curve does not yield an accurate offset curve, see here for an example:
http://moi3d.com/forum/index.php?webtag=MOI&msg=3838.23
9771.5 In reply to 9771.4
Thanks Michael ... you've been clear;)
9771.6 In reply to 9771.5
1st - draw your piece - offset - rebuild the 2 lines ( yellow lines ) - extrude
2nd - apply a large filet - copy paste the borders of the filets - and join them - now you have perfect parallel lines
3nd - draw a profil to sweep the 2 parallel lines - and the swep is ultra clean with same distance everywhere
9771.7 In reply to 9771.6
Thank you corchet :)
