[scripting] Remove that hole!
All  1-3  4-11
9671.4
The ultimate goal output is this image below showing all holes capped -
9671.5 In reply to 9671.4
Hi 9krausec, you can use untrim and then retrim to do that. There is a tutorial here on this kind of object repair work:
http://moi3d.com/forum/index.php?webtag=MOI&msg=446.17
For your case here it would go like this:
Select these faces:
Then use Delete, which will give you this result:
Select the 2 edges that make up this hole:
Then use Delete which will remove that trimming boundary and give you this result:
Now select the 2 edges for the top hole:
And use Delete which removes that trimming boundary and gives this result:
Now for the last hole, it's a little trickier because the hole isn't made from one single trimming boundary, there are 2 trimming boundaries that make up that hole because it is between 2 different faces.
So you'll need to select this face and use Edit > Separate to break it off from the main object:
Then select this edge:
Now use Ctrl+A to select all the face's edges and you will have the entire outer trimming boundary of the face selected like this:
Now when you do Delete you'll see that since this is the outer trimming boundary of the face instead of an inner trimming boundary, the entire "underlying surface" of the face will be recovered and it happened to be a ways larger than the initial visible area:
So now you'll need to use Edit > Trim to cut that face back to the smaller size, or actually in this case a shortcut is to use the ShrinkTrimmedSrf command (http://moi3d.com/3.0/docs/moi_command_reference10.htm#shrinktrimmedsrf) - type Tab then ShrinkTrimmedSrf and then Enter, before you do the untrim and then you you won't have to retrim it.
Do that on the other side too (or mirror the piece) and then use Edit > Join to glue it back together into a solid.
Hope that helps!
9671.6
Thank you Michael for the reply! I'm however trying to do this 100% through your Javascript library which is where I'm scratching my head. If I were to go about this manually, it would be cake. Trying to build up a reusable tool for hole removal. Here are my steps so far that I'm able to get all through Javascript. Maybe you have an idea of a different approach? Below each photo represents a step in my target process. So far, I figured out how to script up to step four.. If you have a better approach or how to proceed past step four, I'm super interested! Thank you.
---------------------------------------------- Successful above this line -----------------------------------------------------
EDITED: 1 Feb 2020 by 9KRAUSEC
9671.7 In reply to 9671.6
Hi Clayton, so you mean you want to do the entire process without any user interaction at all, not even selecting an outline of the hole to remove?
That will probably be very difficult, there is no "recognize what is a hole and what is not a hole" function in MoI, and I don't know how you would approach that in a script.
I guess you might start looking at research papers? You could try "feature recognition" as a search term.
9671.8
moi doesn't have stacking history - so u'll have to repair
better keep all construction lines under a hidden layer & rebuild geometry after
9671.9
"Hi Clayton, so you mean you want to do the entire process without any user interaction at all, not even selecting an outline of the hole to remove?"
^ Yep! I was hoping I could get away with it. So far I've gotten internal holes to work the way I want them to, but these split holes made up of two faces have got me stumped. I'll look into some research papers about feature detection to see if I can decipher and apply their secrets.
After reading up on the topic here on the forum, it seems like their isn't a way to filter edge selection based in surface continuity to be able to target all "hard" edges. Would you please confirm this as the case?
Thank you for all your replies! I'm no where close to a genius, but I'll do some research on white papers as you have suggested.
9671.10 In reply to 9671.9
Hi Clayton,
There isn't any pre-packaged way to do that but I think there is now enough surface evaluation stuff exposed to script that your script could determine this.
That would be something like test several points between edge.domainMin and edge.domainMax , call edge.evaluatePoint( t ) to get a 3d point along the edge, for each face call face.dropPoint( pt ); to get the face's uv parameter space value of the 3D point, call face.evaluateNormal( uv ) to get the normal vector and compare the normals of each face.
I'll see about adding in a more convenient way though.
9671.11 In reply to 9671.10
This is so interesting to me. Following this thread! :)
Show messages: All  1-3  4-11
