Projection Strength- Obj Library *****
All  1-4  5
9636.5 In reply to 9636.1
Hi Alex, yes like Pilou writes above there is a "Projective" option in Transform > Deform > Flow which works like that:
http://moi3d.com/3.0/docs/moi_command_reference8.htm#flow
A couple of notes - the target object should be smooth and all rays from the "base plane" should hit the target object.
If you are having a problem with it please post the .3dm model file with your objects in it.
Show messages: All  1-4  5
