Projection Strength- Obj Library *****
All
1-2
3-5
alexM3D (ALEXMAGNO3D)
4 Jan 2020 (3 of 5)
9636.3
In reply to
9636.2
but not always, the target surface is extruded or loft. Unfortunately that does not solve. could have a simple option of conforming to the surface.
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
Frenchy Pilou (PILOU)
4 Jan 2020 (4 of 5)
9636.4
In reply to
9636.3
Can you send a file 3DM with problem ?
EDITED: 4 Jan 2020 by PILOU
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
Michael Gibson
4 Jan 2020 (5 of 5)
9636.5
In reply to
9636.1
Hi Alex, yes like Pilou writes above there is a "Projective" option in Transform > Deform > Flow which works like that:
http://moi3d.com/3.0/docs/moi_command_reference8.htm#flow
A couple of notes - the target object should be smooth and all rays from the "base plane" should hit the target object.
If you are having a problem with it please post the .3dm model file with your objects in it.
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
Reply to All
All
1-2
3-5
