Bend ?
All  1-3  4-7
9531.4 In reply to 9531.3
Hi Lewis, it looks like Flow could work, however you can't use it only on a part of an object it is for warping an entire object.
So you would want to make an initial "backbone curve" running down the middle of your entire object and then make a new full length backbone curve for your target.
If you can post your .3dm model file I can see if it's feasible or not, if you want to keep it private you can e-mail it to me at moi@moi3d.com
9531.5
Thanks for Help Michael, I've sorted it by a workaround, i've cut/trimmed section of my object near the bottom of "U" and then moved/rotated slightly that part and then recreated area between with blend tool. It's not perfect (i have small bulge whatever settings i use) but it's gonna "pass" on render so all good for now :).
Is Bend tool or rotate with Falloff something NURBS/MOI can even have (in future) ?
Lewis
www.ram-studio.hr
Skype - lewis3d
9531.6 In reply to 9531.5
Hi Lewis,
No, not really, it's not a good fit with NURBS because of how NURBS surfaces have "underlying surfaces" with trim curves on them. The edges where 2 NURBS faces meet up are often times not a natural surface edge but instead a trim curve.
It's a much different structure than a polygon modeler where all polygons share vertices between faces.
There is some description of how trim curves work here:
http://moi3d.com/faq#Q:_Why_does_show_points_work_for_some_objects_but_not_others.3F
9531.7
Understod, thanks.
Lewis
www.ram-studio.hr
Skype - lewis3d
Show messages: All  1-3  4-7
