Permanently expanded side bar menu
All  1-6  7-14
9439.7 In reply to 9439.6
Thanks for your help Michael. Yes, I use a big, hi-res screen so this layout works well for me.
Mark
@ Michael Trivial question
And as "Floating windows" ? So palettes on the Latop and screen on the monitor ?
9439.9 In reply to 9439.8
Things are not really set up for that right now but it is possible with some complications, some info here if you want to experiment:
http://moi3d.com/forum/index.php?webtag=MOI&msg=7394.10
http://moi3d.com/forum/index.php?webtag=MOI&msg=1521.31
http://moi3d.com/forum/index.php?webtag=MOI&msg=1173.17
In the future I want to make an option for having the sidepane and/or scene browser on a separate screen. Not as a floating window but as a docked panel on the side of the other screen.
9439.10 In reply to 9439.3
Would there be a way to exclude the View and Select window from being split since I use the custom ui from max and those are already down in the bottom bar. :)
9439.11 In reply to 9439.10
Hi
Do you know this post : http://moi3d.com/forum/messages.php?webtag=MOI&msg=9758.1
it allow you to do your specific floating menu
Chri
Size: 115.8 KB, Downloaded: 93 times, Dimensions: 584x378px
Size: 49 KB, Downloaded: 80 times, Dimensions: 889x542px
Size: 180.5 KB, Downloaded: 93 times, Dimensions: 1434x693px
9439.12 In reply to 9439.11
I dont want a floating panel :)
Iam just asking if view and select could still be combined while the other tabs are split like Michaels script does.
Thats my current setup:
9439.13 In reply to 9439.10
Hi Chris, try the attached version.
9439.14 In reply to 9439.13
Thx you so much!!
Show messages: All  1-6  7-14
