3DMoi environment & Loft command
All  1  2-3
9425.2 In reply to 9425.1
Hi Ray, you can find a lot of scripts on the MoI web site, go to http://moi3d.com and then the Resources page and go to the link for Petr's MoI page and Max's file archive. There are a lot of scripts collected in both those places and there are instructions for how to install a script on the FAQ.
Re: Loft with path - in MoI that is called the Sweep command, there is some information on it in the help file here:
http://moi3d.com/3.0/docs/moi_command_reference7.htm#sweep
With a quick count, in my MoI setup, I have 156 shortcut keys. (Windows 10, Hi def monitor)
There are probably a few unused key combinations. Some combinations have other computer uses...
(Organization is shaky, at best :-)
This list is not exhaustive.
Script shortcut keys:
Keyboad keys, 39 each
Alt+_ 42 each
Ctrl+Alt+_ 19 each
Ctrl+_ 30 each
Ctrl+Shift+_ 19 each
Shift+_ 7 each
Also, under the CustomUI scripts icon, 442 scripts (including many trial/test versions/ past script writing work in progress).
That is 12 columns of 36 rows, plus top row of 10 more built in scripts like Flip and Rebuild...
Show messages: All  1  2-3
