V4 beta Feb-27-2019 available now
 1-16  …  37-56  57-76  77-96  97-116  117-136  …  217-218
9266.77 In reply to 9266.1
Hello, Michael,
Thank you very much for the new update.
Unfortunately, I couldn't find my externally saved scripts in the script selection so far, although they are stored in the correct directory.
(/Users/moritz/Library/Application Support/Moi/commands). But when I call them manually, they work.
Also, when calling Max Smirnov's script "NutsAndBolts", I get the following error message.
Do you have any idea how I can fix the bug?
Thanks for your help
-moritz
Hello, Michael,
it works now with the version NutsAndBolts.v.0.96.2015.06.22
I have been using the version ... 21
Sorry for the inconvenience
-moritz
Hello, Michael,
The first problem still exists, although the entry in the moi.ini is as follows:
[Commands]
NonRepeatingCommands=delete undo redo
DoNotRepeatShortcutKeys=n
UseDiameterDefault=y
AdditionalCommandsDirs=//Users/moritz/Library/Application%20Support/Moi/commands
-moritz
EDITED: 20 Mar 2019 by MORITZ
Size: 113.9 KB, Downloaded: 154 times, Dimensions: 684x327px
9266.78 In reply to 9266.77
Hi Moritz,
Could you please describe what you mean by "couldn't find" them ? If you type in the command name and it runs, that means MoI is finding them.
9266.79 In reply to 9266.77
Hi Moritz,
> [Commands]
So the AdditionalCommandsDirs there isn't right, you've got it set there as a web URL. For a regular file name you'd want to have just one / at the start insead of // and have a space instead of %20.
But MoI will already look in that directory by default, so it should not be necessary to try and add it using AdditionalCommandsDirs, that's for adding more directories beyond the regular one.
9266.80 In reply to 9266.78
This is correct - when typing the scripts they will be found.
But they do not appear in the selection box.
The change in the moi.ini did not bring any improvement.
-moritz
Size: 54.2 KB, Downloaded: 162 times, Dimensions: 296x279px
Size: 179.2 KB, Downloaded: 176 times, Dimensions: 451x859px
Size: 251.7 KB, Downloaded: 167 times, Dimensions: 755x636px
9266.81 In reply to 9266.80
Hi Moritz, the "selection box" is not a built in part of MoI, it's part of the CustomUI extension.
So first thing to check is are you running an old version of that? You can get the current one from here I think:
http://moi3d.com/forum/index.php?webtag=MOI&msg=6507.268
9266.82 In reply to 9266.81
Hello, Michael,
now I have adjusted everything so far, but now I get the following hint when starting Moi
Where is this report stored so I can send it to you?
-moritz
Size: 45.4 KB, Downloaded: 131 times, Dimensions: 1001x160px
9266.83 In reply to 9266.82
Hi Moritz, actually the report generation for those cases (called an "assert" instead of a crash) isn't hooked up in v4, I'll re-enable it for the next beta.
There may be some information about it in the log though, you can show the log by running this script:
script: moi.ui.createDialog( 'ShowLog.htm' );
Could you please run that copy any text in there and send it to me here or e-mail to moi@moi3d.com ?
Thanks, - Michael
9266.84 In reply to 9266.83
here is the hardcopy (can't copy the text) of this log file
-moritz
Size: 70.9 KB, Downloaded: 133 times, Dimensions: 546x612px
9266.85 In reply to 9266.84
Hi Moritz, thanks for posting that. That one means it can't find one of the "ui", "commands", or "docs" folders inside the normal app package (inside Contents/Resources inside the app).
Did you possibly delete one of those from your installation?
9266.86 In reply to 9266.85
Hi, Michael,
yes, at first I deleted these folders, but then reinstalled MoI. Now it also finds the commands folder in the library directory and the scripts run perfectly. Don't ask me what I did wrong - without your help I would be lost.
Thank you very much for your always quick help ...
-moritz
9266.87 In reply to 9266.86
No problem moritz, I'm glad you are all set up ok now!
Message 9266.88 was deleted
9266.89 In reply to 9266.88
Nodes from Elephant ?
Message 9266.90 was deleted
Message 9266.91 was deleted
9266.92 In reply to 9266.90
Ah yes the Dog-bone and T-Bone corners for your previous post ;)
Else for the offset lines
You can also close by 2 Blends it's more natural :)
But sure it's not automatic for hundred of them! :)
9266.93 In reply to 9266.88
Hi Vladimir,
> Is there any way to automate this kind of rounding of two-dimensional geometry?
Try the attached InsertCircle script, it will insert a circle into your 2D shape with every click which places the circle's center point.
Instructions for installing a plug-in here.
It works like this:
Hope that helps! - Michael
EDIT: 5/29/2021 - added "Flip" option.
EDITED: 29 May 2021 by MICHAEL GIBSON
9266.94 In reply to 9266.93
Funny!
When you click out the space of the closed curve clicked for draw other circles
then that make Union with existant ones!
A sort of blobbing ogre! :)
(inside or outside)
And you can select several closed curves!
And you can change size during the drawing directly to the numeric keyboard!
Bones! ;)
French Version
http://moiscript.weebly.com/insertcircles.html
http://moiscript.weebly.com/uploads/3/9/3/8/3938813/insertcircle_vf.zip
EDITED: 26 Mar 2019 by PILOU
Message 9266.95 was deleted
9266.96 In reply to 9266.95
Hi Vladimir, sorry I don't understand quite exactly what you want it to do. I was thinking you just wanted a quick way to place circles onto a rectangle with some different variations.
It sounds like you were looking for something more specific than that?
Is it that you want to generate the whole shape including the rectangle in one step? What parameters would you want to give?
Show messages:  1-16  17-36  37-56  57-76  77-96  97-116  117-136  137-156  …  217-218
