Segmented Edges | Fillet Error
9220.1
Hello everyone,
One of my edge appears to have multiple segments, which prevents the Fillet command to compile properly.
When I "Join" the segments, it creates a new, separate (detached) curve as oppose to fuse the segments from the original geometry.
The newly created curve was translated upward in image MOI_03.jpg to show it is separate.
Anyone aware of a command that will weld the segments together?
Thank you!
-J
Size: 52.8 KB, Downloaded: 40 times, Dimensions: 1163x937px
Size: 146.6 KB, Downloaded: 35 times, Dimensions: 1177x845px
Size: 178.1 KB, Downloaded: 42 times, Dimensions: 1177x845px
9220.2 In reply to 9220.1
Hi J, there is a Merge command that can glue together segmented edges into longer single edges if they are smooth to each other. Some info here:
http://moi3d.com/3.0/docs/moi_command_reference10.htm#merge
9220.3
That's exactly it. Thank you so much Mike!
-J
9220.4
Thank you for asking and answering this as i too wondered about this, subscribing to the Forum RSS is paying dividends in my moi learning.
