Lofting question
All  1-3  4-8
9094.4 In reply to 9094.1
Hi Andrew, the term "Loft" in MoI means to construct a surface between 2 or more cross section curves, as shown here:
http://moi3d.com/3.0/docs/moi_command_reference7.htm#loft
If I understand your question correctly, you are asking about converting 2D curves into solids by what in MoI is called Extrude, as in here:
http://moi3d.com/3.0/docs/moi_command_reference7.htm#extrude
So to put your question in terms used by MoI, I think you're asking if MoI is able to directly extrude a solid box from a line segment. The answer to that is no - you would need to make a rectangle curve first to extrude to a box. You can use the Construct > Offset command to generate a rectangle from a line segment though, and then extrude that to a box.
For generating text as others mention above it's easiest to use Draw solid > Text will generate solid text from a font.
9094.5 In reply to 9094.4
Michael
First, thank you for your reply. Next, apologies for the delay in my reply as I had been expecting an email to alert me that my forum query had been answered.
In any case, your information and links are quite useful.
Andrew
9094.6 In reply to 9094.5
Hi Andrew, sorry yeah the e-mail notification part of the forum software isn't very reliable. Someday I would like to work on fixing that up.
9094.7 In reply to 9094.2
Stefan,
Many thanks for your reply. Sorry for my delay in thanking you, but I assumed I would be informed by email the someone had responded to my post.
Andrew
EDITED: 28 Oct 2018 by ATHEOKAS
Hi Andrew,
no problem, have fun with MoI! :-)
Show messages: All  1-3  4-8
