Here I am again :)
 1-4  5-21
8958.5 In reply to 8958.3
Many thanks Immortalx!
I've created main lines as per sketch and then I developed surfaces :)
8958.6 In reply to 8958.1
Hello Fabrizio!
First of all, congratulations on your child!
And...your car model is AMAZING.
Ciao!
8958.7 In reply to 8958.6
Grazie Marco!
Ho voluto ricreare nello stile qualcosa che ricordasse l'era delle Gruppo C. Sono soddisfatto del risultato :)
8958.8 In reply to 8958.7
Lo sarei anch'io in questo caso!
Complimenti.
Could you please post some details of the isocurves ? (maybe from Rhino)
Or even its wireframe. Just in order to figure out how is the topology of some of its areas.
8958.9 In reply to 8958.8
Hi Marco, I don't have Rhino ..and I don't know how to generate a wireframe from MoI, but no problem to share with you the .3dm if you want, I guess it should be ok for Rhino as well.
Just let me know, ciao!
8958.10 In reply to 8958.9
Hello Fabrizio!
No...don't worry. No need to send me your 3d model :) ...I was just asking.
Regarding showing the ISO curves in Moi, unfortunately there isn't a quick way, but...one way I use often is leveraging on the wonderful scripts by Max Smirnov/Michael : MultiSo+ (written some yeas ago, but it works on both V3 and V4!)
You can download the MultiIso+ command from : http://take.ms/vkGtx
And this is a quick video tutorial (a very simple example) : http://take.ms/U9bOz
Ciao!
8958.11 In reply to 8958.1
"""""I'm a rookie, so, comments and suggestions are very welcome!"""""
Make sure to get them plenty of sleep.
Let them figure certain things out for themselves.
Give them your important time. They come first.
Nobody has the answers. It's all you man.
Always be kind and loving.
8958.12 In reply to 8958.9
Hi Fabrizio & Marco:
@Fabrizio - a lot of times showing a wireframe just means to also show a screenshot of what your model looks like in MoI in addition to the rendering. That way others can see some of the structure of your modeling like which areas are big surfaces, where some blending connecting pieces are and things like that.
@Marco - I thought you had meant something like that but now I'm not sure since you're talking about the multi-iso script. Did you mean you wanted him to show a model covered with dense isocurves in it?
8958.13 In reply to 8958.12
Hello Michael!
@You "...Did you mean you wanted him to show a model covered with dense isocurves in it?..."
Ho no...certainly not :) I only wanted to ask Fabrizio to show us the topology of only some of the "key" area of its wonderful car.
Just in order, as you said, to figure out how he built the surfaces.
And the "multiiso+" command can be one the easy way to do that without going out of Moi.
8958.14 In reply to 8958.11
"Make sure to get them plenty of sleep.
Always be kind and loving."
many thanks BurrMan for your kind suggestions :) :) :)
8958.15 In reply to 8958.12
Ciao Michael and Marco,
I get start to posting some screenshots, but I also want to try what Marco suggested me. I will post something tomorrow if I can..
8958.16
Wow. First of all congrats on the new family member! Amazing you have *any* time to do *anything!*
Great model and very nice proportions. Nice job!
Here is my 2 cents worth:
Great start. Lack of edge/boundary detail makes it look a bit like a toy car. Focus on the tiny parts, like where the mirror meets the car. The door handles. The details inside the headlights and other lights. Look at existing cars/racecars/ supercars and look at the attention to details that occur between parts and on the edge of parts.
Here are a couple "design" links which might be helpful in understanding edge/boundary and different levels of detail:
http://www.neilblevins.com/cg_education/primary_secondary_and_tertiary_shapes/primary_secondary_and_tertiary_shapes.htm
8958.17 In reply to 8958.1
Wow - nice work! Way to go!
8958.18 In reply to 8958.15
Hello Fabrizio!
Very good model! Congratulation!
8958.19 In reply to 8958.16
Hi Chippwalters,
many, many thanks for your comment and your precious suggestions, in particular about the "design" links you've posted, I'm having a look on it with a lot of interest, as well as I used to follow your tutorials so far!
..and this model is the result of all I gained from this beautifull community!
..but consider that the car still in W.I.P. status, I have to do a lot of things yet, and change some others, and for sure adding more details (also technical) to make it more realistic..
Still a long (and funny) way to go :)
8958.20 In reply to 8958.18
- Marco (mkdm) said:
"Very good model! Congratulation! "
me:
Grazie Marco, è tutto merito vostro, questo è il risultato di tutto quello che sto imparando da voi :)
8958.21 In reply to 8958.16
Very interesting links Chipp, thanks.
There is also similar theories on values (light dark) in a picture.
Marc
Show messages:  1-4  5-21
