Moi as a bridge between Revit and Sketchup
All  1  2-9
8885.2 In reply to 8885.1
Okino PolyTrans 64?
They are pretty much the leader in 3D file type conversions. Plus, their CEO is a hands on guy who has personally helped me build several different conversion pipelines. Great support!
8885.3 In reply to 8885.1
Hi Schiette, sorry yes currently MoI's .skp export does not write material assignments. That is something I want to work on in the future but for now you'll need to find some other conversion software to meet your requirements.
8885.4
Thanks for your replies!
I've tried Nugraf 64 but it was disappointing. Importing the .sat worked but on exporting it to sketchup I got an error before it even started. I also tried importing an .fbx and exporting that as sketchup but there was very bad triangulation.
Moi generates the best geometry conversion from sat to Sketchup I have seen so far. We'd be willing to purchase half a dozen licenses if it was able to generate materials so feel free to contact us as soon as Moi has got this running.
It would also be great if every .sat solid would be put on an individual group. No need for nesting, but now everything is one giant group. Having a separate group for each element would help.
8885.5 In reply to 8885.4
Hi Schiette,
This is actually already implemented in the current MoI v4 beta, so it will be in the next version.
In v4 every separate object in MoI is made into a different group in the .skp file, so for example 2 objects that happen to touch each other in MoI won't have their vertices merged together anymore.
8885.6 In reply to 8885.5
Hey Michael,
That's interesting! Does that mean that the solids will carry through Sketchup as solid groups? If that's the case we could then do some cleanup operations in Sketchup using the solid union operation (I know that could be done in MoI as well but people are more comfortable with Sketchup here).
8885.7 In reply to 8885.6
Hi Schiette,
Yes that should be the case with v4 now - every solid in MoI should come through to Sketchup as a separate group there.
8885.8 In reply to 8885.7
Before the V4 you can export as format 3DS and explode one time inside Sketchup = you have all "Components" ! ;)
They will named "obj0", "obj1", etc...
8885.9 In reply to 8885.8
Thanks Pilou. I tried using .obj but there's terrible triangulation when brought into Sketchup. We want to edit the geometry in Sketchup later on so we want to keep the geometry as clean as possible.
Show messages: All  1  2-9
