Little Tips & Tricks :)
 1-10  11-30  31-50  51-60
8847.31
Wow, thank you very much for this tip.
8847.32 In reply to 8847.29
That's quite a cool technique, Pilou, thanks for sharing!
Regards,
— Metin
visualization • pixel art • illustration • 3D design — https://metinseven.com
have you seen this at ZBCentral? :-)
8847.34 In reply to 8847.33
Yep! Boozy was an old ZB artist friend of the golden age! :)
8847.35 In reply to 8847.33
Pilou and I are trying to get Boozy to hop on board over here. He's a really sympathetic chap.
Regards,
— Metin
I would love to see works from him, done with ZBrush and MoI.
Would be very interesting what he would come up with when using MoI.
BTW. Is he also "The Candy-floss Kid" from the 3DCoat Forum, because
the art style and images looks the same?
8847.37 In reply to 8847.36
<< Is he also "The Candy-floss Kid" from the 3DCoat Forum, because
Of course yes! It's the same guy! ;)
He is specialist of ZBrush, 3DCoat and seems maybe remember C4D!
It's only default : it's an Apple maniac! So missing some free true gem like Verve!
https://www.taron.de/forum/
Verve is based on Fluid's Dynamic but you can make with it any other cool things!
Like this by Knacky! ;)
or more abstract by me :)
EDITED: 6 Mar 2018 by PILOU
Thanks for the info Pilou,
much appreciated.
Hello everyone!
The great Max's Voronoi gave me an inspiration : "How to brake in two each Voronoi cell and make a funny thing" :)
You can find it at : http://moi3d.com/forum/index.php?webtag=MOI&msg=7177.107
Ciao!
Have you a trick for a Multiple NSide ?
Because repeat this on the hundred other different objects seems a little tedious! :)
Making slimy rock
3 Closed Curves
Boolean Merge (Isect can be also used but have less possibilities of choice to erase)
Fillet
EDITED: 9 Mar 2018 by PILOU
8847.42 In reply to 8847.41
Cool!! Thanks.
I usually do not deal with "3 curves" merge...Good to know!
For leaves or fish's bones, trilobites etc... :)
use the Voronoi plugin by Max Smirnov! ;)
8847.44 In reply to 8847.43
Wanderful!!!
Very nice "industrial design" made easy :)
Thanks Pilou!
So...this reinforces more and more my idea about Moi.
Moi is a CAD...but more fun than a videogame !!!!! :)
Thanks Michael!!
8847.45 In reply to 8847.41
Hi!
Pilou seduces to play.
Merge of straight polyline figures.
The remainder of the body mercilessly splintered surfaces.
SubD
That comes out.... just for fun.
Still learned something, thanks.
Franz
https://sketchfab.com/models/80e22d8e486f46939d4d2bba35d8e4ff
8847.46 In reply to 8847.29
Hi Frenchy,
how did I make the explosion?
8847.47 In reply to 8847.46
<< How did the explosion?
Press Tab then write ExplodeMove (big letters as you want but no space)
It's hidden functions!
(you can make a shortcut as usal : type ExplodeMove in the second column)
http://moi3d.com/3.0/docs/moi_command_reference10.htm#Additional commands
8847.48 In reply to 8847.47
Thank you.
Merci.
8847.49
Hi !
I was looking for a way to cause a parallel displacement of a body.
Didn't want to redraw the thing just because the angles had changed.
It is the side of a theatre chair, the inclination of the floor has been changed.
At first I only tried to move the points of the face, at least it works and you are very flexible.
Then played around with "Flow", and it also worked with "Projection".
After "cut and connect" the two results to get the armrest horizontal again.
A very interesting story, this Moi 3d!
Hope the tips and tricks don't fall asleep, I'm an interested student of this post!
Franz
8847.50 In reply to 8847.49
Excellent!
Never thought that the Source base curve or surface can be not "straight" or not "planar" !
Another infinite possibilities! :)
Show messages:  1-10  11-30  31-50  51-60
