A radial move?
All  1  2-5
8802.2 In reply to 8802.1
Hi Dimitri, you might try the ExplodeMove command:
http://moi3d.com/3.0/docs/moi_command_reference10.htm#explodemove
But that works off of the object's bounding box center - for more precise control over placement you're probably better off using Transform > Array > Circular.
At some point I'd like to make arrays work with history, that would probably be what you're looking for really.
You can actually set that up now using the Transform > Rotate command with the "make copies" option. Start with one object, use Transform > Rotate with the "Make copies" checkbox set to place other ones, then select them and use Edit > History > Enable update to turn on history updates for those objects. Then when you change the original one the rotated copies will be regenerated.
I've attached an example file - note when you drag the rightmost circle the others will update.
8802.3
Hi Michael, thanks for the fast reply! I will try the methods you mention but... how do you activate the 'explode move'? Is there a script to put to the shortcut keys menu?
8802.4 In reply to 8802.3
Just press TAB and write explodemove, or EplodeMove or anything you want as big letters but no Sp ac e, point,_,-, etc!!!
You can also make a shortcut as usual and write explodemove on the secound column!
8802.5
Thanks Pilou! This was, exactly, what I needed! : - )
EDITED: 2 Feb 2018 by DIMITRI
Show messages: All  1  2-5
