Lots of unkown
 1-16  …  217-236  237-256  257-276  277-296  297-316  …  357-372
8665.257
discovered smt new today !
if curves are mirrored & attach each other -> they can extrude a solid object without union ! neat !
- Tudor -
8665.258
hotkeys
add point
c - close curve
d - delete corners
- Tudor -
8665.259
Hi Michael, I've made gif vods of my scripts -> got error
The page was not displayed because the request entity is too large.
- Tudor -
8665.260 In reply to 8665.259
Hi Tudor, can you show a screenshot of the exact error message?
8665.261 In reply to 8665.259
Also does it only happen when you're using https:// and not http:// ?
8665.262 In reply to 8665.259
Also the max size for an individual file uploaded as an attachment is 10MB, is your file larger than that?
There is also a limit of 50MB for all attachments, if you have a large file it is better to upload it to a file sharing service like Dropbox, etc... and then have a link to it here rather than have a very large direct file attachment.
8665.263
vods for scripts that i've made
https://www.dropbox.com/sh/80jbog45r5k9hcu/AABQOif-bXD9QgLVgMYZAv3da?dl=0
move http://moi3d.com/forum/index.php?webtag=MOI&msg=8665.219
offset http://moi3d.com/forum/index.php?webtag=MOI&msg=8665.211
fillet, inset, shell, offset(Brep) http://moi3d.com/forum/index.php?webtag=MOI&msg=8665.197
chamfer http://moi3d.com/forum/index.php?webtag=MOI&msg=8665.217
isoCurve http://moi3d.com/forum/index.php?webtag=MOI&msg=8665.213
add point extended scripts http://moi3d.com/forum/index.php?webtag=MOI&msg=8665.258
~ loop _ExpandSelectionTangecy http://moi3d.com/forum/index.php?webtag=MOI&msg=8665.195
~ grow edge loops _GrowSelectionTangecy http://moi3d.com/forum/index.php?webtag=MOI&msg=8665.195
bool difference - http://moi3d.com/forum/index.php?webtag=MOI&msg=8665.182
extrude - http://moi3d.com/forum/index.php?webtag=MOI&msg=8665.182
trim - http://moi3d.com/forum/index.php?webtag=MOI&msg=8665.171
rect3pts with center - http://moi3d.com/forum/index.php?webtag=MOI&msg=8665.164
extend tangency http://moi3d.com/forum/index.php?webtag=MOI&msg=8665.158
Union+Join http://moi3d.com/forum/index.php?webtag=MOI&msg=8665.140
filter - http://moi3d.com/forum/index.php?webtag=MOI&msg=8665.108
round corners rectangle http://moi3d.com/forum/index.php?webtag=MOI&msg=8665.76 + http://moi3d.com/forum/index.php?webtag=MOI&msg=8665.204
mirror x/y http://moi3d.com/forum/index.php?webtag=MOI&msg=8665.75 + http://moi3d.com/forum/index.php?webtag=MOI&msg=8665.11
polycut http://moi3d.com/forum/index.php?webtag=MOI&msg=8665.18
usefull in combination with perspective script and
zbrush side snap http://moi3d.com/forum/index.php?webtag=MOI&msg=8665.23
usefull
planar from 3 edges http://moi3d.com/forum/index.php?webtag=MOI&msg=8665.73
- Tudor -
8665.264
Ohayo
Michael can u make last message as first one ? so It should be ~ pinned
another script
scale + s -> scale bbox
- Tudor -
8665.265 In reply to 8665.264
Hi Tudor,
Sorry I'm not sure how to do that. I can put a link to the first one in the wiki resources page though, would that help?
Thanks, - Michael
8665.266
I'll make a new topic just for scripts, here will be questions !
- Tudor -
Message 8665.267 deleted 30 Nov 2020 by CEMORTAN_TUDOR
8665.268
ohayo
wanna ask about rotation - wanna do a to bounding box option on pressing hotkey
first testing on curves -> there's an option in v4 -> crv.planarFrame
tested - but it's shifts from bounding box -> gives planar frame but in another location
my questions ->
1. knowing 2 coordonates is it possible to make a frame ? accordigly to http://moi.maxsm.net/ it needs 3 (as it is from bbox to frame)
2. if upper is true wich will be (z) knowing x & y, next hotkey for flipping axis ()
3. if they are other scrips for rotation ?
shortly what I desire (unify rotation with some extra)
r - rotate
rr - rotate + bbox (planar frame 2d)
rrw(rrs) - rotate bbox + increase/decrease by amount (2d)
rrf - rotate from bbox + flip axis (x/y/z)
rrfw(rrfs) - rotate increase/decrease by amount (3d)
rc - rotate copy
rrc - rotate + bbox + copy
ra - array
rra - array from bbox
- Tudor -
8665.269 In reply to 8665.268
Hi Tudor,
Well 2 points does not identify a unique frame, the 2 points can form a z axis direction for the frame but there is nothing that locks down the x/y axis directions to a single answer. Depending on what you need it can be possible to do something like the AutoCAD arbitrary axis algorithm (link) where you take a fixed direction like the world z axis and use cross product of that and the z axis to produce an x axis.
If you want the 2 points to be an axis to rotate around, you could try the RotateAxis command or factory, that takes 2 points instead of a frame and then a rotation angle and the rotation will be around the direction vector between those 2 points.
Sorry I don't understand this one.
ScriptArray:
http://moi3d.com/forum/index.php?webtag=MOI&msg=5595.18
RotateArray:
http://moi3d.com/forum/index.php?webtag=MOI&msg=9710.5
RotateAndExtrudeFace:
http://moi3d.com/forum/index.php?webtag=MOI&msg=8126.34
8665.270
any plans for opensubd ?
an example https://youtu.be/gzyO8S5FLUU?t=181
- Tudor -
8665.271 In reply to 8665.270
Hi Tudor, yes I do plan on supporting OpenSubdiv style edge weighting imported through FBX format.
8665.272
Ohayo !
wanna ask about techincal aspects hiding behind cad modeling
what's the reason to have always a solid shape ? why can't be done a bool operation of a plane and a surface knowing the plane normals ?
- Tudor -
8665.273 In reply to 8665.272
I believe it's essentially for Print 3D : you must have a thickness different than "0"
so a solid and not a simple plane surface who can't exist in the reality! ;)
And some practical for know how cost some volumes of materials for building or what is the density of something! ;)
But in Moi you can make Boolean operations with plane, surface with thickness = "0" !
EDITED: 2 May 2021 by PILOU
8665.274 In reply to 8665.272
HI Tudor,
That's because MoI is designed to try and not behave differently depending on which direction an open surface happens to have as the "positive" normal direction.
The booleans are based on working with solids. If you are working on all surfaces you should use the Trim command instead of booleans usually.
8665.275
ohayo
dragging points from a curve doesn't snaps to points of the same curve
- Tudor -
8665.276 In reply to 8665.275
Hi Tudor,
Yes, that's intentional to avoid having consecutive points get stacked up on top of each other too easily, such stacking degrades some of the mathematical properties of the curve and can cause problems.
Show messages:  1-16  …  197-216  217-236  237-256  257-276  277-296  297-316  317-336  …  357-372
