Lots of unkown
 1-3  …  204-223  224-243  244-263  264-283  284-303  …  364-372
8665.244 In reply to 8665.243
Hi Tudor, you could make a post here in the forum and then link to the forum thread. Github is a good idea too though.
8665.245
rectangle interactive
the idea is to combines all rectangles under one shortcut and switch between them from hotkeys
q rect
w rect center
e rect 3pt
r - will be added - http://moi3d.com/forum/index.php?webtag=MOI&msg=8665.164 -> rect with 3ptcenter ~ another way to grow new rectangles
script is unfinished
- Tudor -
8665.246 In reply to 8665.245
Hi Tudor.
Only one rectangle ;-)
EDITED: 30 Sep 2020 by WN
Size: 26.9 KB, Downloaded: 73 times, Dimensions: 276x245px
8665.247
looks a like a runtime error, I dont have it !
it's about moi version or smt else not related to the script
or it might ask for html .. that I havent work on, try to add if it works
EDITED: 30 Sep 2020 by CEMORTAN_TUDOR
8665.248 In reply to 8665.247
Hi Tudor.
Ok!
8665.249
Ohayo
will be possible to improve antialiasing on plane surfaces ?
- Tudor -
8665.250 In reply to 8665.249
Hi Tudor,
> Ohayo
Not for v4 but possibly at some point down the road.
8665.251
Thnkas !
& I have one more modeling challange ! I was looking around moi todo it
It's a new year toy that has to be twisted ~~~ I gave up doing in moi
- Tudor -
Size: 203.8 KB, Downloaded: 77 times, Dimensions: 463x745px
8665.252 In reply to 8665.251
Hi Tudor, maybe try the Transform > Deform > Twist command for that. Something like this:
8665.253
no control over twist, and ~ the countour that i need ~ misses the uv
- Tudor -
Message 8665.254 deleted 31 Oct 2020 by CEMORTAN_TUDOR
8665.255
any way that fillet g1-g3 could have a second slider for adjusting scaling*?
- Tudor -
Size: 56.8 KB, Downloaded: 85 times, Dimensions: 1052x800px
8665.256 In reply to 8665.255
Hi Tudor,
There isn't any way to set that up now but I would I would like to give some attention to Blend in the future and that is one of the things that I would like to do. Bring it up again when the v5 beta is underway.
8665.257
discovered smt new today !
if curves are mirrored & attach each other -> they can extrude a solid object without union ! neat !
- Tudor -
8665.258
hotkeys
add point
c - close curve
d - delete corners
- Tudor -
8665.259
Hi Michael, I've made gif vods of my scripts -> got error
The page was not displayed because the request entity is too large.
- Tudor -
8665.260 In reply to 8665.259
Hi Tudor, can you show a screenshot of the exact error message?
8665.261 In reply to 8665.259
Also does it only happen when you're using https:// and not http:// ?
8665.262 In reply to 8665.259
Also the max size for an individual file uploaded as an attachment is 10MB, is your file larger than that?
There is also a limit of 50MB for all attachments, if you have a large file it is better to upload it to a file sharing service like Dropbox, etc... and then have a link to it here rather than have a very large direct file attachment.
8665.263
vods for scripts that i've made
https://www.dropbox.com/sh/80jbog45r5k9hcu/AABQOif-bXD9QgLVgMYZAv3da?dl=0
move http://moi3d.com/forum/index.php?webtag=MOI&msg=8665.219
offset http://moi3d.com/forum/index.php?webtag=MOI&msg=8665.211
fillet, inset, shell, offset(Brep) http://moi3d.com/forum/index.php?webtag=MOI&msg=8665.197
chamfer http://moi3d.com/forum/index.php?webtag=MOI&msg=8665.217
isoCurve http://moi3d.com/forum/index.php?webtag=MOI&msg=8665.213
add point extended scripts http://moi3d.com/forum/index.php?webtag=MOI&msg=8665.258
~ loop _ExpandSelectionTangecy http://moi3d.com/forum/index.php?webtag=MOI&msg=8665.195
~ grow edge loops _GrowSelectionTangecy http://moi3d.com/forum/index.php?webtag=MOI&msg=8665.195
bool difference - http://moi3d.com/forum/index.php?webtag=MOI&msg=8665.182
extrude - http://moi3d.com/forum/index.php?webtag=MOI&msg=8665.182
trim - http://moi3d.com/forum/index.php?webtag=MOI&msg=8665.171
rect3pts with center - http://moi3d.com/forum/index.php?webtag=MOI&msg=8665.164
extend tangency http://moi3d.com/forum/index.php?webtag=MOI&msg=8665.158
Union+Join http://moi3d.com/forum/index.php?webtag=MOI&msg=8665.140
filter - http://moi3d.com/forum/index.php?webtag=MOI&msg=8665.108
round corners rectangle http://moi3d.com/forum/index.php?webtag=MOI&msg=8665.76 + http://moi3d.com/forum/index.php?webtag=MOI&msg=8665.204
mirror x/y http://moi3d.com/forum/index.php?webtag=MOI&msg=8665.75 + http://moi3d.com/forum/index.php?webtag=MOI&msg=8665.11
polycut http://moi3d.com/forum/index.php?webtag=MOI&msg=8665.18
usefull in combination with perspective script and
zbrush side snap http://moi3d.com/forum/index.php?webtag=MOI&msg=8665.23
usefull
planar from 3 edges http://moi3d.com/forum/index.php?webtag=MOI&msg=8665.73
- Tudor -
Show messages:  1-3  …  184-203  204-223  224-243  244-263  264-283  284-303  304-323  …  364-372
