>> If Spaceclaim does what you need, you should get it, you can use MoI in combination with Spaceclaim quite well. I think it supports copy and paste between MoI using the Rhino clipboard format although I'm not sure if that's still active in the current version.
Yeah but Spaceclaim is super expensive. Even so i really like Moi3D and how everything works and looks...and i gladly paid for it even if i could choose Fusion360 for example which i didn't quite like (workflow related mostly in general).
The main point here is few very important features that Moi3D should have or should be able to do. I really don't need massive amount of features, i can do a lot with just what Moi3D has but it would be great if those features are really not limiting.
What i mean by that is that Moi3D is aimed mostly for artists and "concept modeling", fast and fun, but the thing is that you are losing quite a bit of that fun when you want, for example, fillet something (hah, that fillet again..lol) and it just can't do it in certain situation and fails as soon as things get a bit more complex. Or an single edge is getting in a way and fillet fails (where other software solutions just make it across the edge no problem) so you have to go though elaborate, tedious and often more advanced techniques to get rid of that pesky edge so that fillet can work. Easy to do if you have some simple planer surface but very often you just can't delete face and use "Planer" - done.
I understand though that it's not everything easy to do, cost money and takes a lot of time especially when you are doing all the work alone! I am doing also a bit of scripting myself and i know very well know how it is like when people request to just add that "small" little thing. :)
Cheers.
