How to rotate and Move along path line ?
 1  2-21  22-24
8411.2 In reply to 8411.1
Hi nordzway, it's helpful if you would also post the 3DM model file with your curves in them instead of only a screenshot. With the 3DM file it's much easier to test different things and give better advice.
But from what I can tell in your screenshot you would use the Construct > Sweep command to do that. But it looks like you're only selecting a single profile curve for your sweep. Instead of selecting just one profile curve you would need to select both the starting and the ending profile before doing the sweep.
You can give Sweep multiple profile curves to control the shape at each station, it's not limited to only one profile curve.
8411.3 In reply to 8411.2
hi michael,
your method works ( sweep )
But my problem is i have to rotate manualy each profil, i just need a regular torsion or a regular rotation to the start profil to the last
for now if i need to rotate my self is pretty bad ^^
Size: 201 KB, Downloaded: 40 times, Dimensions: 1238x262px
8411.4 In reply to 8411.3
and if i select the first and the last profil and i just sweep tool
i have a corrupt result some line is mixed...
Size: 217.4 KB, Downloaded: 41 times, Dimensions: 764x476px
Look Transform /Array / Circular
Look Transform / Array / Curve
Look also at Array 3D by Max Smirnov! ;)
http://moi3d.com/forum/index.php?webtag=MOI&msg=7574.26
French version http://moiscript.weebly.com/scripts-de-max-smirnov.html
So make first with the Profil
Apply _Array3D or other
Then Loft
EDITED: 5 May 2017 by PILOU
8411.6 In reply to 8411.5
je vais tester ça
EDITED: 5 May 2017 by NORDZWAY
8411.7 In reply to 8411.6
bon en faite avec array 3d ça ressemble à ce que je veux faire, mais le petit problème c'est qu'on ne contrôle pas trop ^^
si seulement je pouvais selectioner le profil de debut puis celui de fin et ensuite lancer array 3d pour créer les profils intermédiaires ce serait parfait...
Je me demande même si j'ai pas déjà vu un plug sketchup qui fais ça...
There is also the native Flow Function! :)
8411.9 In reply to 8411.4
Hi nordzway,
Please post the 3DM model file so I can take a look.
8411.10 In reply to 8411.9
thank you michael,
its just for testing, but, i think my best option for achieve my test its maybe Something like " path constrain "
Is a script exist maybe ?
thank you
8411.11 In reply to 8411.10
Hi nordzway, if you post the 3DM file I can give you some better tips.
re: path constrain - there is the Flow function under Transform > Deform > Flow, where you can map a shape from a straight line backbone to a curved one. To use that way you would just extrude your shape to make it initially straight, then use Transform > Deform > Twist to twist it, then draw a line down the center of it and use the line as the base curve for a curve to curve Flow. There is more information on Flow here: http://moi3d.com/3.0/docs/moi_command_reference8.htm#flow
It's also possible that the glitch you show above is just a display artifact and the actual surface is ok. That's something that I could check if you would post the 3DM model file instead of only screenshots.
If sweep is generating something bad between 2 profiles, it's probably because of the twist reduction mechanism in Sweep - normally sweep tries to align shapes in such a way to reduce twist. If you're running into that, then you could try initially placing the 2 end profiles for the Sweep to be non rotated, then do the sweep and introduce the twist by rotating the end profile after the sweep is done using history updating to update the sweep. That's another thing to try.
8411.12 In reply to 8411.11
thank you again Michael,
Yes flow works !
Now the top, is for me a script capabalities to move and deform on spline in the same time
EDITED: 6 May 2017 by NORDZWAY
8411.13 In reply to 8411.12
Hi nordzway, also try the sweep method with rotating the profiles after you've completed the sweep. The history function will kick in and update the sweep dynamically as you manipulate the profile, no script is required.
8411.14
ok y try
8411.15
I think the only things i need is the same option " Torsion FIXED " in sweep tool
but in te flow tool !
EDITED: 9 May 2017 by NORDZWAY
Size: 654.8 KB, Downloaded: 17 times, Dimensions: 852x773px
So a possibility: Transform / Array / Curve / Flat
Loft
then Extrude if you want a rectangle
or if you want other thing like first Post draw just a profil and make a simple Loft! :)
PS But Seems you have Flat options inside the Sweep function! So more easy!
Set Flat direction gives some funny result! :)
EDITED: 9 May 2017 by PILOU
8411.17 In reply to 8411.16
Merci pilou
pas de problème pour ton exemple, par contre dès que je change de direction, les profils ne se mettent plus perpendiculaire par rapport à la spline
comme tu peu le voir, si je reprend ton exemple mais que je créer une petite descente hé bien mes profil ne se fixent pas perpendiculairement, apparement le changement
d'axe horizontal/vertical pose problème (me pose problème)
et j'ai évidement une spline qui parcours les deux axes, du coup comment garder cette perpendicularité des profil, car si je met en " libre " c'est l'anarchie et les profils sont inclinés
Merci
Size: 262.4 KB, Downloaded: 37 times, Dimensions: 827x690px
So no rotation + perpendicular to the curve ?
So maybe use Array Curve for distribute a number of Points Along the curve
Then use the Transform / Orient / Orient function and copy on these points your profil! :)
8411.19 In reply to 8411.18
ok thank you i try this
8411.20 In reply to 8411.19
ok but, this operation equal to move manualy all profils ^^no ?
8411.21 In reply to 8411.20
ça c'est sûr! :)
Quelle est la courbe de départ?
J'ai du mal à comprendre si l'on veut un volume en quoi un Tubage à un ou deux Rails ne répond pas à la question ?
Même à un rail...
Si c'est pour un toboggan Pipes 2 devrait faire l'affaire ?
Show messages:  1  2-21  22-24
