Export Import Moi3d - 3dCoat
All  1-8  9-14
8315.9
Another key point is whether or not you're looking to 'voxelize' in 3D Coat or just use 3DC to apply appropriate UV maps. I've been doing the latter a lot lately with Rubbermaid and Coleman CAD files and it works great as a basic UV Mapping tool and PBR shader workflow. You can then use Marmoset, Element 3D, Unity, UE4 or InstantLight.
Using 3D Coat, it's easy to add normal map wrinkles, bumps and textures on your model (in my case a tent) and you don't need (or really want) a super high poly model. Lots of times smaller is better.
Also, something very interesting I posted on one of my last videos: Exporting from MoI3D to SketchUp can create a better smoothed normal object for import into 3D Coat. 3DC doesn't have normal map smoothing and a 'coarser' mesh coming out of MoI3D can have smoothing errors (see my video starting at 9 minute mark:)
Lastly, for those interested in Unity, I'm getting some very high rez photoreal renders (realtime) out of it using MoI models. While I can't show any at this time, I will be adding some more public ones soon and will gladly share. The 3DC -> Unity is a wonderful workflow as it's so damn easy to go back and forth using the 3DC->Unity plugin.
Also, the same is VERY TRUE for SketchUp to Unity (save in SU 2015 format) and you can easily go back and forth with the built in SU support. It's pretty cool as you can assign those cheesey maps in SU to objects, (which is a MUST if you want to map in Unity-- assigning an image texture map in SU automatically generates UVs for the model-- though not necessarily very good ones) then double click the images to open them in Photoshop, upscale them 8X and add in your own texture and then save and it's automatically loaded back into Unity-- wonderful! Also, you can take an RGB texture, duplicate it, and add it as a NORMAL map in Unity and it will automatically render it out as a normal map. Pretty sweet.
Truly the SU workflow in Unity is something to behold-- especially if going to VR. Cool stuff!
I don't know if that can interest you but there is new tool for SKetchUp or as Standalone :)
Access closses 28 february! ;)
http://wrap-r.com/
8315.11 In reply to 8315.10
Yep saw this and downloaded it already. Very well done! Finally a professional level UV unwrapper for SketchUp!
8315.12
Do I get this?
Workflow between Moi3d & 3dCoat is complimented by using SketchUp as an intermediary too?
Does that make spending 695 USD a necessity?
Cheers,
8315.13 In reply to 8315.12
No you have SketchUp Make for 0$ !
Pro is only for "Pro use" who need to program Dynamic Components, Layouts for architects and some function like Boolean*...;)
SketchUp Make is not licensed for commercial work.
With "Make" you can use Dynamic Components!
And of course 99% of Plugins (maybe more 2 000 plugins are existing for anything! )
https://www.sketchup.com/download?sketchup=make
(when you downoad "Make" you have "Pro" version functions for a month then becomes "Make" !
As we say :Moi is the "SketchUp of the Nurbs" so you can imagine how easy it is! :)
You can even use SketchUp as Subdivision with 2 "Plugins"
Artisan (39$) https://artisan4sketchup.com/
or SUbD (20$) http://evilsoftwareempire.com/subd
Else SKetchUp is the program who have the more Render engines dedicated! :)
The more easy and funny is this free one!
http://getvisualizer.com/ (till SketchUp 2016)
else this very free cool one (maxi 1920 *1080) SimLab Composer Light (as it's a Standalone you can use it for Moi! )
: http://www.simlab-soft.com/3d-products/simlab-composer-freelicensee.php#light
etc...
* Booleans are now existing for "Make" for 20 $ ;) http://mindsightstudios.com/booltools-2/
PS You can also use SketchUp for free "Online" but there is no plugin! (not recommanded for that you want but funny!
and very pedagogic for learn & use only native tools! :)
https://www.sketchup.com/products/my-sketchup
My little try(s) of my SketchUp :)
EDITED: 22 Feb 2017 by PILOU
8315.14
Well that's more good news! Thank you for that!
Show messages: All  1-8  9-14
