Tyre Tutorial - Flow problems
All  1-7  8-19
8273.8 In reply to 8273.5
Hello val2
Thank you for your response. I see what you have done...
I guess that is one way of doing it. When you get some time
have a look at these tutorials;
https://www.youtube.com/watch?v=QwCXd1zMnSQ&t=123s
https://www.youtube.com/watch?v=Q5-tLNpnhpw&t=11s
I followed the tutorials exactly, but my results were different.
I think it has something to do with the fact that my surface is joined.
Thank you again.
Cheers.
Sandeep.
8273.9 In reply to 8273.6
Hello Michael,
thank you for your explanations.
When I deselect rigid, the issue still persists : (
and I have used the rebuild command and followed the same process,
but I am still getting the same result.
Have a look at these tutorials; why can't it be as easy as how Chipp does it : )
Cheers.
Sandeep.
8273.10
Hello to Brian, val2, PILOU and Michael...
I finally managed : ) !!! ..Michael your suggestion to REBUILD curves did the trick. I used #points and set the number to double of the default.
It basically changed the curve when revolved to a SURFACE. Which is what Chipp achieved in his video. (How did he do it without the rebuild command?....)
Thank you to you all for your quick response, much appreciated as always!
Cheers. Sandeep.
I made this
- Copy move the circle's wheel
- UnwrapeCurve by the Michael's Plugin http://moi3d.com/forum/messages.php?webtag=MOI&msg=5136.1
- Extrude the Line obtained
- Copy the module (Array Line)
then Flow
Any problem :)
How many time take your Flow function ?
With above the Flow has taken one half minute
(middle module + little line is your file)
EDITED: 22 Jan 2017 by PILOU
8273.12 In reply to 8273.11
Hello PILOU, thank you for the alternative.
My flow took around one minute to do : )
Thank you again!
Sandeep.
8273.13 In reply to 8273.10
Hi Sandeep, sorry I wasn't able to give you better information the first try, so what you've run into here is the control point spacing of your curve affecting the flow.
If you draw a control point curve and have some control points close together and others far apart from each other, it will make the "parameterization" of the curve also be similarly bunched together and stretched out, and for a surfacing command that preserves the exact structure of the curve into the surface it will mean the UV parameterization of the surface will be the same.
If you rebuild the curve before doing the revolve, it solves it because the rebuilt curve has much more even parameterization.
8273.14 In reply to 8273.13
Hello Michael,
thanks for the deeper explanation.
I will repeat the process a few times, so i get a better understanding all of this.
I am still curious about how Chipp managed to do it in his video, without re-building...?
Any thoughts?
Cheers.
Sandeep.
8273.15 In reply to 8273.14
part 1 : minute 5.25 - 5.40
he made the extrude line surface here from the original surface and no need the rebuild it!
EDITED: 23 Jan 2017 by PILOU
8273.16 In reply to 8273.15
Thank you PILOU. I doubled checked the video.
You are right, but when i rebuild the curve and revolve, it seems to
resolve the issue i was having. Especially since the tyre is now a surface.
I will do this tutorial again and let's see if it works without REBUILDING.
Speak soon.
Cheers.
Sandeep.
8273.17
Hello everyone! I finally did it! Lot's and lot's of learnings on this one.
Thank you for your help!
Sandeep.
8273.18
Coming a bit late to this thread, but I'm glad you're able to complete the tire, Sandeep. Your render looks FABULOUS!
8273.19 In reply to 8273.18
Hello Chipp!
Thank you for your response, i tried to reach out to you via your YouTube channel too.
Thanks for the great tutorial!
Cheers.
Sandeep.
Show messages: All  1-7  8-19
