ICONS - GUI Closed
 1-3  4-23  24-41
8236.24 In reply to 8236.23
Hi Ced, re: "extremely complex natural organic shapes" - MoI is just not designed to do that type of job, it's focused on making it very quick and easy to do simple man made mechanical types of shapes. I'd guess this may be fundamentally why you're trying to find all these other kinds of scripts that are not prepackaged with MoI, but you'd probably be better off using a tool that is more in line with the type of work that you're trying to do.
  More Options
8236.25 In reply to 8236.23
> I see so many ways to make the GUI striking - and the software loaded like a
> nest of yellow jackets - and I want it that way. I'm creating just that - however
> - it's more difficult than necessary - and I wonder why -
Well, MoI is fundamentally intended to be easy to use and have a light and streamlined workflow and UI. The concept of "loaded like a nest of yellow jackets" is pretty much exactly opposite of those goals, so that's the reason why.
There are already other programs out there that cater to the "loaded like a nest of yellow jackets" type of design, but a lot of people find the complexity that goes along with that has a lot of negative side effects like being hard to learn for example. The reason why MoI exists is to provide a counterpoint to that, to make a CAD tool that puts accessibility as a fundamental target.
Now of course you're certainly welcome to use MoI in other ways than what it was designed for, and I've made things quite flexible so that it's possible to modify MoI in many ways to suit your needs, but still the simple answer to why it isn't set up the way you want is that it's designed with different goals than what you have.
  More Options
8236.26
Yes & no. People customize 'normal' motorcycles into monsters - and the EASE OF USE and SENSIBILITY which is inherent in Moi3d is incomparable to other CAD software - e.g., Blender is a nightmare, ProEng is a complete disaster (for my purposes), and I intensely 'dis' CLOUD based lease programs - so Moi3d is the 'sweet spot' - it's sensible - easy to use - easy to learn - and it's lightening fast to work within - however - it's a NAKED MAJA in my view.
Therefore - adding the ornaments is like decorating a tree - or customizing a motorcycle - turning Moi3d into a hotrod!
I'm accomplishing that task - it just seems apparent that if there were a REPOSITORY where all these scripts were - and would UNZIP into the COMMANDS FOLDER - why not?
Why not even get people to sign a release and sell them? I'd throw some GUI SKINS & ICONS into the bag -
Cheers,
Vlad the Impaler
  More Options
8236.27 In reply to 8236.26
Hi Ced,
Well as I've said seemingly over and over again, that is indeed something I want to add in to MoI. It just has not happened yet because other things are higher priority. The reason why it is not a very high priority is because (again as I explained above) the "loaded like a nest of yellow jackets" type of concept is not what MoI is fundamentally aimed at. Things that align more closely with MoI's main design goals just come first.
  More Options
I am unsure of issues regarding the distinction between commercial and open source, but some unofficial scripts might have "open source" code
with various "license" types... (?)
  More Options
8236.29
Other than the godrays piling through the clouds, I'm particularly not fond of that interface. I guess it does harken back to a time when game interfaces and skeuomorphic interfaces were all the rage (I've certainly seen and designed my share of them!).
Frankly, the MoI3D interface is clearly defined by design to be simple, friendly, unassuming and approachable. So is the logo and brand. It's not meant to be Gigantor Enterprises, but rather a lifestyle company with best-in-class customer support and superior ease-of-use. If that's the correct brand message-- it's coming through loud and clear.
For those interested in more complex interfaces, there are plenty to choose from. If the requirement is lots of organic capabilities, I might suggest 3D Coat. It's a huge program with a steep learning curve with which you can build just about anything...as long as it's not supposed to be part of a CAD file somewhere.
I applaud Michael's design sensibilities and focus on simplicity. As one who has just recently switched from Mac to PC, and then tried to work in Powerpoint having worked the past years in Keynote, I can attest to Michael's "simpler is better" rule when it comes to interface design. Ugh! The ribbon interface is just HORRIBLE!
  More Options
8236.30
Uh - yeah. The point I'm making is that there are gadZillions of super cool specialized SCRIPTS that go into the COMMAND FOLDER buried in the forum. I'm suggesting that if someone when through all the drivel on this forum with a minesweeper and ferreted out all those scripts and placed them into a ZIP FILE that would install them directly into the command folder - in one fell-swoop - like a dump truck load - that would be totally sick. However, better yet, would be an ADD-ON that would permit you to SORT which ones you wanted - and whether or not you wanted a POP-UP WINDOW with the ICONS or prefer to have a bloated SHORT-CUT key style access - one or the other - myself - I prefer the icons in a window - and throwing in a few SKINS wouldn't hurt either - like this:
Most damned beautiful interface with the sickest set of custom scripts ever!
Moi Resident Artist,
Agrafena Quackenbush
  More Options
8236.31 In reply to 8236.30
"""""". I'm suggesting that if someone when through all the drivel on this forum with a minesweeper and ferreted out all those scripts and placed them into a ZIP FILE that would install them directly into the command folder - in one fell-swoop - like a dump truck load """""
The zip file linked to here is exactly that (minus the forced into the actual MoI root folder. Thats because not everyone wants the entire truckload.) Is it really that hard to unzip it and move the whole thing in? I can make a zip for you that will do that.
Including the UI customization is a moot point. You dont want how i have customized mine.
Also, Michael answered he is planning everything you're requesting.
UI customization can be acheived with the gui builder script by chipp! But thats kindof moot too, if you want to follow the development of MoI.
  More Options
8236.32
Yeah - Like buying a factory car - then you get the 'leather seat covers' + 'Bose speakers' + racing wheels - et al and the dealer tells you you can find them in the junk yard - go dig there.
Having, rather, to do nothing more than peruse a CHECKLIST and SELECT the add-ons - and UNZIP into the commands folder all the HOT ADD-ONS would turn this chimp into KING-KONG!
The benefit of Moi3d - in my humble opinion - is that Michael has some sort of aberration in his development in which he's developed a CAD designer's DAY DREAM - in terms of drivability -
In other words - all the other CAD programs handle like a FORD TAURUS where's Moi3d handles like a Bugatti - in terms of handling tools.
Like Apple - they are compulsive obsessive minimalist's - to the extreme - they made minimalism ugly and Apple's glory has been snuffed-out.
Michael - on the other hand - has developed the SUSPENSION in a CAD program that gives it DRIVABILITY - it handles super! However - the PANCAKE MIX AUNT JEMIMA style GUI with the EXTREME COOL STUFF sitting in boxes in the WOMEN'S AUXILIARY LOUNGE isn't wise - when they - the cool GUI'S & custom SCRIPTS - could be unpacked and added with a few terse clicks -
That stuff is like adding NITROUS OXIDE to your Moi fuel!
SCRIPT: Take the 'Poincaré Conjecture' - "In mathematics, the Poincaré conjecture (/pwɛn.kɑːˈreɪ/ pwen-kar-ay; French: [pwɛ̃kaʁe])[1] is a theorem about the characterization of the 3-sphere, which is the hypersphere that bounds the unit ball in four-dimensional space. The conjecture states: Every simply connected, closed 3-manifold is homeomorphic to the 3-sphere.
An equivalent form of the conjecture involves a coarser form of equivalence than homeomorphism called homotopy equivalence: if a 3-manifold is homotopy equivalent to the 3-sphere, then it is necessarily homeomorphic to it.
Originally conjectured by Henri Poincaré, the theorem concerns a space that locally looks like ordinary three-dimensional space but is connected, finite in size, and lacks any boundary (a closed 3-manifold). The Poincaré conjecture claims that if such a space has the additional property that each loop in the space can be continuously tightened to a point, then it is necessarily a three-dimensional sphere. The analogous conjectures for all higher dimensions had already been proved.
After nearly a century of effort by mathematicians, Grigori Perelman presented a proof of the conjecture in three papers made available in 2002 and 2003 on arXiv. The proof built upon the program of Richard S. Hamilton to use the Ricci flow to attempt to solve the problem. Hamilton later introduced a modification of the standard Ricci flow, called Ricci flow with surgery to systematically excise singular regions as they develop, in a controlled way, but was unable to prove this method "converged" in three dimensions. Perelman completed this portion of the proof. Several teams of mathematicians verified that Perelman's proof was correct." https://en.wikipedia.org/wiki/Poincar%C3%A9_conjecture
The Poincaré conjecture, before being proved, was one of the most important open questions in topology. and so to have a SCRIPT that would unravel a 3-sphere so that each loop can be continuously tightened to a point would be MY DREAM!
However - I'm an artist - not a SCRIPT WRITER.
Therefor I troll places (ha-ha) where I can find scripts which I think may help me achieve - as an anti-minimalist - my goals - which are another story. Basically, not that it matters - 'steam/diesel punk with soft/hard/rotten parametrics & surf flowing' design - hybrid natural with man-made - my own garden variety marmalade.
What's gripped me - is Michael's common sense suspension - Moi3d's handling is HOT HOT HOT!
Cheers,
H. Gene Variation
  More Options
8236.33 In reply to 8236.32
So the answer is no then! lmao......
  More Options
8236.34
Burrman - watch this https://vimeo.com/188437534 and have the script on my desk in the morning!
  More Options
8236.35 In reply to 8236.34
Seems you have (or not) seen my post one day ago! :)
http://moi3d.com/forum/index.php?webtag=MOI&msg=8265.1
  More Options
8236.36 In reply to 8236.34
The script is in the zip file. You just have to install it.
  More Options
8236.37
BurrMan - You're fired! ha-ha!
  More Options
8236.38
Frenchy - great! Now turn Poincaré Conjecture into a script for me and you can have the rest of the day off - deal? After all - it was your compatriot's fault you're at fault for us not having that script - which will unroll a surface per the solution! Go figure the French make a problem & the Russian's solve it. Now it's your turn Frenchy - to save the honor of France. Apparently Burrman is in the Ladies Auxiliary Lounge unpacking all those script files so he's no use to God nor man - saving the world now rests on your shoulders - God speed!
  More Options
8236.39 In reply to 8236.37
Wow Ced,
You're a real winner there! I think I've been blinded by your genius. I'm out.
  More Options
Message 8236.40 deleted 15 Jan 2017 by MICHAEL GIBSON
8236.41 In reply to 8236.38
Ced, the forum is not a place to get into long drawn out flame wars and provoke other people. I will lock this thread now since it's devolving and you seem intent on disruption, you can start another topic later but please try to avoid the bad behavior.
  More Options
Show messages:  1-3  4-23  24-41
