Rotate 90 Script/Hotkey
All  1-2  3-11
8224.3 In reply to 8224.2
Hey Michael. This is exactly what i was looking for... and what a nice little piece of code!
Thanks a ton.
8224.4
Hello Michael,
I'm curious if V3 scripts will work on V4?
Carlos
8224.5 In reply to 8224.4
Hi Carlos, yes in general they should. I think it's possible that a few may need minor edits due to a couple of bug fixes here and there.
8224.6
Cool! : ) Thanks
8224.7 In reply to 8224.5
it don“t works with my MOI V3.1 ... 8-(
Happy Xmas
moritzbock
Size: 19.7 KB, Downloaded: 14 times, Dimensions: 217x193px
8224.8 In reply to 8224.7
Hi Moritz, you would get that error if the QuickRotate.js file was not copied over into your commands folder, there are some instructions on where to copy it here: http://moi3d.com/faq#Q:_How_do_I_install_a_plug-in_script.3F
The error happens because no command named QuickRotate was found in the commands folder, and so instead MoI tried running the contents of the shortcut key as script code itself rather than loading it from the QuickRotate.js file.
8224.9 In reply to 8224.8
the QuickRotate.js file is in the right place - like the other ...
moritzbock
Size: 381.7 KB, Downloaded: 65 times, Dimensions: 1029x1137px
8224.10 In reply to 8224.9
Hi Michael
I'm embarrassed. I put the QuickRotate.js into the wrong MOI folder (V3 instead of V3.1 !!!)
Always the same mistake - shame on me 8:(
moritzbock
8224.11 In reply to 8224.10
No problem Mortiz, I'm glad you got it sorted out!
Show messages: All  1-2  3-11
