Showcase of very personal Moi
All  1  2-9
8122.2
Definitely one hot rod customized interface. I think you have virtually every plugin, script, shortcut, workflow ever developed for MoI. Good thing you know your hotkeys!
8122.3 In reply to 8122.2
Hi chippwalters,
and good morning.
Aaaahhhhhh LOL....yes, in fact I still have a good memory, but I also wrote for myself the "Shortcuts Summary Dialog" (Shift+Z) :) :)
Best,
8122.4
Wow, nice work Marco! I haven't customized MoI yet, but I know from my ever-evolving custom ZBrush UI how a customized interface can be a never-ending journey towards perfection.
The only part of MoI I've customized is the keyboard shortcuts. Here they are:
[Shortcut Keys]
/=script: /* Isolate selection */ moi.geometryDatabase.isolate();
0=script: /* 3D view (perspective or isometric) */ moi.ui.mainWindow.viewpanel.mode = '3D';
1=script: /* Front view */ var vname = 'Front'; var vp = moi.ui.mainWindow.viewpanel; vp.mode = vname; if ( vp.getViewport(vname).name != vname ) vp.reverseView( vname );
3=script: /* Right view */ var vname = 'Right'; var vp = moi.ui.mainWindow.viewpanel; vp.mode = vname; if ( vp.getViewport(vname).name != vname ) vp.reverseView( vname );
5=script: /* Toggle between Parallel and Perspective view */ var vp = moi.ui.mainWindow.viewpanel.getViewport('3D'); vp.projection = (vp.projection == 'Perspective' ? 'Parallel': 'Perspective');
7=script: /* Top view */ var vname = 'Top'; var vp = moi.ui.mainWindow.viewpanel; vp.mode = vname; if ( vp.getViewport(vname).name != vname ) vp.reverseView( vname );
A=ArrayDir
B=Blend
Backspace=Delete
C=script: /* CPlane */ moi.view.setCPlaneInteractive();
Cmd+A=script:moi.geometryDatabase.selectAll();
Cmd+C=CopyClipboard
Cmd+E=Export
Cmd+I=script: /* Invert selection */ moi.geometryDatabase.invertSelection();
Cmd+N=New
Cmd+O=Open
Cmd+R=Randomize
Cmd+S=Save
Cmd+V=Paste
Cmd+X=Cut
Cmd+Z=script:moi.command.undo();
Ctrl+1=script: /* Back view */ var vname = 'Back'; var vp = moi.ui.mainWindow.viewpanel; vp.mode = vname; if ( vp.getViewport(vname).name != vname ) vp.reverseView( vname );
Ctrl+3=script: /* Left view */ var vname = 'Left'; var vp = moi.ui.mainWindow.viewpanel; vp.mode = vname; if ( vp.getViewport(vname).name != vname ) vp.reverseView( vname );
Ctrl+7=script: /* Bottom view */ var vname = 'Bottom'; var vp = moi.ui.mainWindow.viewpanel; vp.mode = vname; if ( vp.getViewport(vname).name != vname ) vp.reverseView( vname );
Ctrl+A=ArrayCurve
Ctrl+C=cMorph
Ctrl+D=DistortCurves
Ctrl+E=Scale2D
Ctrl+F=AddPoint
Ctrl+I=Isocurve
Ctrl+K=script: /* Select naked edges (open borders) */ var gd = moi.geometryDatabase; gd.deselectAll(); var breps = gd.getObjects().getBreps(); for ( var i = 0; i < breps.length; ++i ) breps.item(i).getNakedEdges().setProperty( 'selected', true );
Ctrl+M=Merge
Ctrl+N=New
Ctrl+O=Orient
Ctrl+P=script: /* Copy PDF format to clipboard */ moi.geometryDatabase.copyToClipboardPDF();
Ctrl+R=RailRevolve
Ctrl+S=Separate
Ctrl+Shift+A=ArrayGem
Ctrl+Shift+C=CopyClipboardWithOrigin
Ctrl+Shift+D=Copy
Ctrl+Shift+R=Rebuild
Ctrl+Shift+S=script:/* Shrink selection 1.0 */ function es(edg){ var i,f; for (i=0; i<edg.length; i++) {f=edg.item(i).getFacesOfEdge(); f.setProperty('selected',0);}} var gd = moi.geometryDatabase; gd.invertSelection(); var so = gd.getSelectedObjects(), sf=so.getFaces(), i; gd.invertSelection(); for ( i=0; i<sf.length;i++) es(sf.item(i).getEdges());
Ctrl+Shift+V=PastePart
Ctrl+Shift+X=script:/* Expand selection 1.0 */ function es(edg){ var i,f; for (i=0; i<edg.length; i++) {f=edg.item(i).getFacesOfEdge(); f.setProperty('selected',1);}} var so = moi.geometryDatabase.getSelectedObjects(), sf=so.getFaces(), i; for ( i=0; i<sf.length;i++) es(sf.item(i).getEdges()); es(so.getEdges());
Ctrl+V=Paste
Ctrl+X=Cut
Ctrl+Y=script:moi.command.redo();
Ctrl+Z=script:moi.command.undo();
D=BooleanDifference
Delete=Delete
DownArrow=Nudge Down
E=Scale
F=script: /* Show all in viewports */ moi.view.resetAll();
F1=script:moi.launchHelp();
H=script: /* Hide selection */ moi.geometryDatabase.hide();
I=BooleanIntersection
J=Join
K=script: /*Edge loop selection*/ moi.geometryDatabase.selectLoop();
L=Loft
LeftArrow=Nudge Left
M=Mirror
N=NSided
O=Offset
P=PlanarSrf
PageDown=Nudge ZDown
PageUp=Nudge ZUp
R=Rotate
RightArrow=Nudge Right
S=Sweep
Shift+A=ArrayCircular
Shift+B=BoundingBoxCenter
Shift+C=script: /* Reset CPlane to default */ moi.view.resetCPlane();
Shift+Cmd+C=CopyClipboardWithOrigin
Shift+Cmd+S=SaveAs
Shift+Cmd+V=PastePart
Shift+Cmd+Z=script:moi.command.redo();
Shift+D=DelCorners
Shift+DownArrow=Nudge Down Small
Shift+E=Scale1D
Shift+F=ShowPoints
Shift+H=script: /* Select objects to unhide */ moi.geometryDatabase.showSubset();
Shift+I=Inset
Shift+K=script: /* Select edges v1.4 */ var gd=moi.geometryDatabase, so=gd.getSelectedObjects(); function ss(o,v){o.setProperty("selected",v)} function sl(o){ for ( var i=0; i<o.length; ++i ) o.item(i).getEdges().invertProperty("selected");} gd.selectLoop(); sl(so.getFaces()); sl(so.getSolids()); sl(so.getOpenBReps()); sl(so.getSingleFaceBReps()); ss(so.getBReps(),0); ss(so.getFaces(),0);
Shift+L=script: /* Lock selection toggle */ moi.geometryDatabase.lock();
Shift+LeftArrow=Nudge Left Small
Shift+M=BooleanMerge
Shift+N=Network
Shift+O=FatLines
Shift+P=Project
Shift+PageDown=Nudge ZDown Small
Shift+PageUp=Nudge ZUp Small
Shift+R=Revolve
Shift+RightArrow=Nudge Right Small
Shift+S=Shell
Shift+U=UnwrapCurve
Shift+UpArrow=Nudge Up Small
Shift+V=Chamfer
Shift+Z=script: /* Toggle edge display */ var breps = moi.geometryDatabase.getObjects().getBReps(); var hide = true; for ( var i = 0; i < breps.length; ++i ) { var edges = breps.item(i).getEdges(); if ( i == 0 ) hide = !edges.item(0).hidden; edges.setProperty( 'hidden', hide ); }
Space=script: /* Toggle quad view */ if ( moi.ui.mainWindow.viewpanel.mode != 'split' ) { moi.ui.mainWindow.viewpanel.mode = 'split' } else { var viewport = moi.ui.getViewportUnderMouse(); if ( viewport ) { viewport.viewPanel.mode = viewport.name } }
T=Trim
U=BooleanUnion
UpArrow=Nudge Up
V=Fillet
W=Move
X=Extrude
Z=script: /* Toggle visibility of all curves */ var objs = moi.geometryDatabase.getObjects().getCurves(); var ishidden = objs.length> 0 ? objs.item(0).hidden : false; objs.setProperty( 'hidden', !ishidden );
A number of key bindings correspond with either Blender or ZBrush, for convenience.
I decided to start a discussion for sharing your keyboard shortcuts here:
http://moi3d.com/forum/messages.php?webtag=MOI&msg=8123.1
All the best,
Metin
EDITED: 5 Oct 2016 by METINSEVEN
8122.5 In reply to 8122.4
Hi Metin Seven,
and thank you for sharing your hotkeys.
Yeah...you're absolutely right !
P.S. If any of you want to share also a screenshot or a video of his customized Mpoi, you are welcome.
Best,
8122.6 In reply to 8122.4
Hello Metin, Hello Marco,
very cool customiziation and a interesting list of shortcuts. I only use a few shortcuts and my only customiziation is a button for hideswap - I wonder that I haven't seen that!?
Have a nice day
Karsten
8122.7 In reply to 8122.6
Hi Karsten,
and thanks for your reply!
What do you mean for "hideswap" ?
...maybe I've already got it into my tools arsenal...it's a very crowded Place... :)
Best,
- Marco (mdkm)
8122.8 In reply to 8122.7
Hello Marco,
http://kyticka.webzdarma.cz/3d/moi/#HideSwap
Very useful when want to hide only a few objects and bring them later back by selection - its like the show/noshow in CATIA.
Have a nice day
Karsten
8122.9 In reply to 8122.8
Hi Karsteen,
Hit and Sunk! Aaaahhhhhh LOL :)
I immediately proceeded to include that shortcut into my workflow !
Ciao,
Show messages: All  1  2-9
