PBR pipeline for MOI3D using 3D COAT and KEYSHOT
 1-6  …  27-46  47-66  67-86  87-95
8108.67
Hey Chipp
I found this course on retopo in 3d Coat https://www.udemy.com/retopology/learn/v4/overview
At £15 (half price today) pounds it seemed worth a punt. I dont know when I will have time to have a go but if I learn anything useful I will share it here. The trouble with being a nurse is that I don't get much time to experiment with this software. The trouble with being 55 is I forget what I learn in between sessions;)
Best regards
Keith
8108.68
Hi Keith,
55? Oh, to be young again! FWIW, I do have the same problem trying to remember all the stuff from various programs-- that's one reason why I make YouTube tutes.
Thanks for the iink-- bought the course and also bought one of Scott's AE courses (I have a video project due in the next couple of weeks).
8108.69 In reply to 8108.66
Hi Chipp!
You're welcome.
> "... quick modeling exercises.."
Did you create all that "quick modelling" in 3D-Coat from scratch in two ours ?
Chipp, listen to me.....you're becoming a Master!!
I wait tuts from you!!
> "I'm waiting on a tutorial on how to use Instant Light!"
I've been practicing with this new very interesting brand new tools and it seems to be very very promising,
and me too I'm waiting new tuts from its developer :)
Thanks for your sharing and have a nice day.
EDITED: 30 Dec 2016 by MKDM
8108.70 In reply to 8108.66
Hi Chipp and everyone.
Here's a random assembly made just to see how my actual config can handle with decent speed
high-poly count voxels in 3D-Coat.
Well...on my laptop (i7 4790K 4.4 Ghz 32Gb Ram Nvidia Quadro K3100M 4Gb) almost all modelling processes remains very responsive,
while only realtime rendering is very slow.
4 objects, 26Mil polygons.
Here's the render retouched with the great Affinity Photo.
Best,
@Klaudio : few facts
ZBrush / 3D Coat
No traditionnal UI / Traditional UI
Ultra detailed models managment of billions of polygons / a little few less ;)
Voxels hidden for the user / Full managment of Voxels
Better to learn ZBrush if you want work in Movie - video sculpture characters!
Both are magic program!
Have happy new year!
PS @ Klaudio
ZBrush Top Raw 2016 ;)
8108.73 In reply to 8108.70
Hi Marco,
Still plugging away on workflows. Now playing around with 3DCoat -> Toolbag (baking) -> AE Element 3D -> VR
Another one I want to try is MoI3D (hi-rez poly and lo-rez poly meshes) -> 3D Coat (voxelize and add detail to high poly mesh then retopo and UV normal/displacement map using MoI low poly mesh). If I can get that to work it would be *very cool.*
I also just received the gift of a Vive to start playing around with (but I have to use Unity...)
One other thing. If possible (and it's not too much trouble) could you possible upload your large images as the code below? This way it doesn't force the whole browser (and other messages) to go wide. Once someone 'clicks' on the image it will open in a new tab at full resolution. Thanks!
<a href=http://www.myurl.com/image.jpg><img src=http://www.myurl.com/image.jpg width=1024></a>
8108.74 In reply to 8108.73
@chippwalters
Yes!This is a feature should be implemented by default Michael... ;)
8108.75 In reply to 8108.73
Hi Chipp!!
I'm glad to hear you again!
> You wrote : "Another one I want to try is MoI3D (hi-rez poly and lo-rez poly meshes) -> 3D Coat (voxelize and add detail to high poly mesh then retopo and UV normal/displacement map using MoI low poly mesh). If I can get that to work it would be *very cool.*"
Yes! Worflow Moi3D -> 3DCoat is absolutely amazing in order to retouch Mechanical things made in Moi3D to make them more natural and organic!!
It's one of my favorites workflow :)
> You wrote ; "One other thing. If possible (and it's not too much trouble) could you possible upload your large images as the code below? This way it doesn't force the whole browser (and other messages) to go wide. Once someone 'clicks' on the image it will open in a new tab at full resolution. Thanks!"
Thanks a lot for the suggestion. ASAP I will try it.
About InsatntLight it's true that it has a not finished UI, but their new RC1 to RC4 versions are AMAZING from the point of view of SPEED
and QUALITY of the realtime PBR rendering ind DirectX 11 e 12.
If they will improve a bit its UI, InstantLight will be a very valid and powerful tool.
I think, MUCH MUCH more powerful than the more famous Mormorset Toolbag 3.
Have a nice day and see you.
EDITED: 18 Jan 2017 by MKDM
8108.76 In reply to 8108.74
Hi Mauro,
I've managed to modify the forum so that wide images will automatically be shrunken down, when it happens a text label "Image has been resized, click for full size." will appear below the image and if you click on the image the full sized image should open up in a new tab.
If you want the old behavior of no size limiting, you can disable it under forum Options > "Display" section > disable "Resize images and reflow page to prevent horizontal scrolling." checkbox.
8108.77 In reply to 8108.76
Hi Michael.
> You wrote : "I've managed to modify the forum so that wide images will automatically be shrunken down..."
Thanks a lot for adding this very necessary feature to the forum.
See you.
8108.78
Thanks Michael ! :)
Thank you very much Michael!
You're all welcome! I also added in a link to the "light" version on the forum login page to use for mobile. That one uses no frames and simplified text output.
8108.81 In reply to 8108.1
Hi Chipp and everyone!
Just another very interesting workflow involving in this case, not MOI, but only Rocket3F, 3D-Coat, InstantLight and Affinity Photo.
This workflow complements the other one that I'm already testing and using with very good results, that is Moi->3DCoat.
Look at this resources :
A Realtime recorded video with water and rain effects!
The original video was recorded in FullHD but I made a mistake during Youtube upload and the final
quality is very bad (360p).
https://www.youtube.com/watch?v=62KZYV6HU1k
https://rocket3f.com/forum/showcase/115-experiments-and-epic-fails?start=150#2372
https://rocket3f.com/forum/showcase/115-experiments-and-epic-fails?start=150#2384
https://rocket3f.com/forum/showcase/115-experiments-and-epic-fails?start=150#2389
See you.
Last image is very cool!
8108.83 In reply to 8108.82
Thanks Pilou!
It's only thanks to InstantLight and its realtime VFX.
Ciao!
8108.84
Good for you. Looks like you're enjoying Instant Light :-)
8108.85 In reply to 8108.84
Hi Chipp!
Yes! I'm exploring the various possibilities offered by this new and very peculiar realtime renderer coupled with 3D-Coat.
If only I had a more powerful Nvidia Quadro card... (my good old Quadro K3100M 4Gb seems to mark time).
And you ?
What are you experimenting with 3D-Coat ? Let us know :)
For the moment I'm trying to improve my hard surface workflow : Moi -> 3DCoat.
See you.
8108.86 In reply to 8108.85
Hi Marco,
I'm currently exploring similar pipelines. I've been hired by a large east coast consumer products company to help create their AR/VR product visualization strategy. I'm now working on bringing CAD files into a virtual environment and being able to view it on a Vive headset. In particular, I'm exploring workflows and pipelines into Unity and UE4. I suspect there may be some tutorials along those lines, as well as CAD (in my case MoI) -> 3D Coat -> Marmoset (optional) -> UE4 and/or Unity.
Stay tuned for what I hope is an interesting discussion :-)
Show messages:  1-6  7-26  27-46  47-66  67-86  87-95
