Hi chippwalters,
I write you here in reply of your post
http://moi3d.com/forum/index.php?webtag=MOI&msg=7954.52
because i think that i'm "Off topic" if i continue to use the thread "Project moi3d v4".
> I'm curious if it can also export maps that KeyShot can use?
I think there are several ways to do that in 3D-Coat...
If you want to directly work on hi-poly meshes, a possible workflows are :
METHOD 1
1) File -> New
2) Close the splash screen
3) Go to the "Paint Room"
4) File -> "Import model for Per Pixel Painting"
5) Do painting job in "Paint Room"
6) Finally export all, with File -> Export Objects & Textures with "Export Geometry"
At this stage you can choose what Export/Import workflow is better suited for yout receiving app, (KeyShot in your case) :
A) Gloss/Color Specular
B) Gloss/Metalness
C) Roughness/Metalness
METHOD 2
1) File -> New
3) File -> "Import model for PTEX"
4) Do painting job in "Paint Room"
5) Finally export all, with File -> Export Objects & Textures with "Export Geometry"
B) Gloss/Metalness
For both methods, I think that the best Export/Import workflow for KeyShot are A and C.
Or maybe it's better for you to use the "KeyShot Advanced" with Roughness/Metalness.
P.S. i'm using latest version of 3D-Coat : 4.7.06 64Bit
Ciao!
