Morphostemic Anti-Gear …
 1-13  14-33  34-53  54-65
8030.34 In reply to 8030.32
Super slick Ty !
Thanks for sharing.
8030.35
@> mkdm -- Imaginary — in each, there's usually half a dozen “things” i’m trying to accomplish from a modeling or rendering perspective — so they are primarily driven by learning — however, I try and make them interesting as well.
@> PaQ — Thank you — !
Technologic! :)
8030.37
Pilou -- thank you -- !
8030.38
Ty.
Sweet. Very.
You should check out 3D Coat for some other ways of accomplishing 'sketching' in 3D. I've a tute or two up on YouTube. FWIW, 3D Coat also works great as a UV mapping tool for MoI3D (forget the topology unless you just want to play around). Works great and you can work directly with PBR and send to KeyShot.
8030.39
Chipp,
I've been looking into 3D Coat -- and very close to diving in -- my only worry is that renders often look kind of doughy -- but I've been told the speed of the workflow compensates for this -- will check out the videos -- thank you.
TyRuben
8030.40
Colleagues,
Finally found time to finish this one.
R
T
Technologic!
8030.42
OMG! I must have missed this thread... Impressive stuff! Great design and cool renderings!
8030.43 In reply to 8030.1
Very nice work Ty.
Inspirational and well done!
8030.44
Hi Ty,
Yes, you are correct, there is the 'doughy' thing. If you check out my video on 3D Coat Live Clay you'll see a way to work around some of that:
https://youtu.be/I9qMtMhrRbs
8030.45 In reply to 8030.40
Hi TyRuben!
Very impressive rendering and interesting subject too!
Congratulations!
8030.46
Pilou -- Giai77 -- Scooter -- Chipn -- Marco -- Thank you -- !
@> Chipp -- Will definitely check out your video -- thank you -- I've really learned a great deal from you -- !
R
T
8030.47
Thanks Ty.
Learning new things is fun. I've recently been porting some of my older stuff, (like the drone ambulance I did awhile back for FASTCO
https://www.fastcodesign.com/3041696/this-drone-ambulance-is-totally-wild-and-totally-inevitable) into room-scale VR and it's amazing what you find out about your designs when you blow them up to real size. In my case I found out the Drone was too short, too wide, the seat too large, the gurney too large. Too much attention to tiny details and not enough attention to mid-scale details ( http://www.neilblevins.com/cg_education/primary_secondary_and_tertiary_shapes/primary_secondary_and_tertiary_shapes.htm ).
It's a fascinating design learning experience. If you have access to a GEAR VR headset you can see:
https://altuit.cloud/web/dbpub/3D/img00239636241799841671917Screenshot.jpg
8030.48
Colleagues,
Do to a number of unexpected professional twists and turns, I find myself the owner of a new Mac book, and as such, I’d like to start running MOI on it. I’m sure the question is answered here on the forum many times, however, as I have a pair of new renders to post, I thought I’d just inquire here. If I download and install MOI on a second machine, do I simply put in my license key from the e-mail I received after my original purchase?
My guess is yes, however, I thought it worth asking.
Thank you!
Rage on,
Ty
You can install any number of Moi on any machine: the only thing : you must use only one version in the same time!
So yes the same key license number will work!
Ps : Stuning model!
8030.50 In reply to 8030.48
Hi Ty, your render looks great! And yes like you thought and like Pilou said you just use your same license key that you received in e-mail. The original download links in that e-mail expire after 2 weeks but you can get a new download by putting in your license key here: http://moi3d.com/reinstall.htm
And yes like Pilou wrote above, you can install your same one purchased MoI license on any number of machines you own just as long as it's only actively launched and running on one of those installs at a time. You would only need to purchase an additional license for some other machine if you wanted some other person to be running it there at the same time.
One other note, if you're running the new Sierra OS on your new machine, you've got to move the MoI app into the /Applications folder for it to run due to some new download security mechanisms.
8030.51
Michael & Pilou,
That's great news -- thank you both -- !
These are busy times -- wish I had more time to just work on what I want.
Rage on,
Ty
Have you a site where we can see all that imaginary things ?
8030.53
As of yet, no I do not.
I do have a Facebook page:
https://www.facebook.com/Morphostemic/
However, most everything there is here.
R
T
Show messages:  1-13  14-33  34-53  54-65
